Results 1 to 7 of 7
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Replaced battery - now all 3 FOBs won't remotely lock/unlock the doors
    I recently replaced my battery and seem to have immediately lost the sync between all three of my fobs. I can physically un/lock the doors by using the key, so that all seems to work fine.
    Do I need to go through the programming process using VCDS or is there some short-cut procedure?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Try sticking your key in the ignition, then press and hold the lock button on the fob, then turn the key to the on position (do not start the car), then turn to off position. Your fob should be synced again.
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    I know this doesn't solve your problem, for which I apologize, but this sort of thing is why I always patch in a 12V source via the OBD2 port when pulling the battery. Do this and you'll never have this sort of problem again.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    To re-sync the key fob simply insert key, turn to on position, wait 5 seconds, turn to off position, remove key. Done. (It’s in the manual).
    And believe me, I know. I had to re-sync one of my keys probably a hundred times. If you are bored, read this thread for a little entertainment. KEY FOB CRAZINESS
    Jul 03 2010
    New York
    Finally got a chance to try this and no luck at all. Tried it with all 3 FOBs and nothing.
    I'm not sure if it makes a difference but I have upgraded to the B7 FOBs and the ...433BB modules. Wait, check that, I've got two B7 FOBs and one B6 FOB.
    Jul 03 2010
    New York
    Quote Originally Posted by Cybersombosis View Post
    Thank you - this ^^^ worked!
    Funny enough, it only worked with one of the B7 FOBs. Then I realized the batteries were dead on my two spares! Looks like it's a CR2025 battery for the B7 FOB and a CR2032 for the B6 FOB.
    Jan 24 2010
    Paramus,NJ USA
    B7 fob should be a 2032 coin cell battery. Make sure the key part number starts with 8E0 otherwise the key fob will not work and needs to be FCC ID MY4073A.
    Ziddy Autowerks
