Results 1 to 6 of 6
Thread: Intake hose
    Junior Member One Ring JayDee03's Avatar
    Aug 03 2014
    1969 VW Bug convertible
    Denver
    Intake hose
    I have a strange issue that I have never seen or heard of before. I have a silicone intake hose from ECS, and every so often it develops a perfectly evenly distributed mist of oil over it's entire surface, even on the underside of it. What's so strange is not just the perfectly uniform coverage of the mist, but that there's absolutely ZERO oil of any kind on ANYTHING else on the rest of the engine, including the area immediately around the intake hose or the clamps. Strangely enough, even the inside of the hose is oil free . I have the updated version of the Provent 200 oil/air separator with the pressure release on the inside, and initially thought it was the Provent venting pressure when I had the previous version with the pressure release on the exterior, so it's not that. This is the second hose I've had from ECS, because I assumed the first was defective, and oil from the intercooler hoses was permeating the layers of silicone on boost and creating the mist. Yet the same thing is happening with this hose, and this never happened with the stock hose.
    Has anyone ever experienced this with a silicone hose, particularly the intake hose?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The material is a weave and allows oil to weep through.
    2019 SQ5 Prestige
    May 03 2013
    FRANCE
    I have same problem with CTS turbo hoses, I don't know if it is normal or if it's due to poor quality.
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    It's completely normal, silicone hoses are porous to oil.
    https://www.siliconehose.com/blog/wh...-rubber-hoses/
    May 03 2013
    FRANCE
    Ok, thanks for the link, it explains why the only one that was dry on my car was the one between the air box and the turbo. So for JayDee03, maybe it's better to keep the original PCV system instead of adding a provent oil/air separator
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mats16RCGTI View Post
    ohhhh yeah .. especially if your area is prone to freezing .. PCV valves these days are extremely complex, especially on turbo cars.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
