Getting low oil pressure light do not drive on dash. Oil level is fine, I can definitely tell something is off when starting. Sounds slightly like a power steering whine almost. Have not driven more than a couple hundred feet while this light is on. Car has just under 40k. 034 stage 1 e85. See some posts on oil pressure switch’s that have went bad but that wouldn’t cause the entire oil pump to shut down would it? There is definitely something off I’m assuming the oil pump which seems very low mileage to be replacing. Has anyone had similar issues with the 3.0 oil pressure like this?
