Originally Posted by
Liquid Smoke
i'm in NYC as well, on my B9.5 S5 i'm running 275/35/20 Vredestein Hypertracs on the stock 20" Black Optic wheels. i have no plans to lower it either, great size i'd recommend it, feels more comfy and "protected" and gives you peace of mind on bad roads. you can see my profile thread history i have the tire thread somewhere with more info and pics. or might be on another forum -
https://www.audiworld.com/forums/aud.../#post25747296
So this a is huge increase in the rolling diameter of the tire over the stock 265/30 on the 20" S5 wheel. One can obviously do this, but it is way out of the range of what is recommended to do. Also note that it raises the overall height of the car my 17mm. On the other hand, it also lessens your visual fender gap by the same 17mm on a stock suspension. Whether one likes the overall look is an individual decision. It will certainly give a bigger air cushion for bad roads.
For the OP.......opinions and choices will be all over the place depending on what is important to you,
and what your goals are. Some people really only care about appearance and not performance. Despite the fact that they bought a performance car, it is all about the "look" and the "image". That will lead you down a very different path than if you want a car that is best as a real daily driver. Different, still, will be if you actually want to maximize performance. I have been tuning and modifying cars for over 40 years and have seen it all. I have also seen people (myself included) go down the rabbit hole of doing a mod, which then needs another one, which then needs another one, etc. So....if you want to go to any kind of extreme, that is a choice you should make after fully understanding what you are getting into.
If not, and you have the 20x9" ET34 wheels on your S5 with 265/30 sized tires, and are keeping stock suspension height, I would do one of the following:
1.) 20x9.5 with a 30mm offset and stay with the stock 265/30 tire size
2.) 20x9.5 with a 34mm offset and go to 275/30 tires.
3.) 20x9 with a 26-28mm offset and stock 265/30 tires (this will give a slightly more flush look, not alter your scrub radius too much, but will be the lightest wheel option staying with 20" wheels)
One of these will give you a good overall balance between looks, performance and daily drivability. If your goals are different, then you can go down a different path.
The other option, if you are really concerned about bad roads is to downsize to a 19" wheel and go with 265/35/19. This would also save weight which is never a bad thing. Going with a smaller wheel and larger sidewall tire will also decrease your visual fender gap appearance. Finally, look at the weight of both the wheel and tire you are considering. No point in spending extra money to have boat anchors at the corners!!
