Results 1 to 20 of 20
    Jul 16 2018
    Atlanta
    Exclamation PSA: Gen2 2.0T crank bolt has new torque instructions, 8.8 vs 10.9
    In early 2021, the vibration damper to crankshaft TTY bolt was changed from the long standing WHT 001 760 to a new WHT 009 475. It appears this new bolt is a 10.9 bolt, whereas the prior bolt was an 8.8. Being TTY, this means the same torque instructions will not produce the same end result. It appears Audi updated the torque instructions in the Dec '21 edition of the workshop manual.
    See Smoker324's post of the updated workshop manual page in this thread: https://www.audiworld.com/forums/a4-...ocess-3049215/
    So 8.8 bolt, it's 150 Nm + 90°
    & 10.9 bolt, it's 100 Nm + 180°
    Veteran Member Four Rings MyDimeIsUp's Avatar
    Dec 04 2019
    West Chester, PA
    Quote Originally Posted by Smac770 View Post
    Must've explained why my grandfather and I felt like the bolt was about to snap and we couldn't even get the +90 degrees. We were using 2016 edition of the workshop manual. Just double checked and we used the 475 bolt. Now we had to remove it since there was a slight leak from the timing cover so technically I shouldn't be using the bolt but whatever.
    2020 BMW M340i xDrive - Mineral Grey
    2012 Audi A6 3.0T Prestige - 034 Stage 1 ECU and TCU | CTS Turbo Intake | 034 Street Density Motor Mounts w/ JHM Trans Insert | ECS X-Pipe
    2013 Audi allroad - RIP
    2007 Toyota corolla
    Junior Member One Ring
    May 21 2022
    Boston
    Thanks Smac770 you beat me to the psa. We should get the word out. Let me tell ya. 180* is something else. 4 foot breaker + 5 foot pipe + one plus sized 275 lb old guy dangling off the end of the 9 foot lever was barely enough to get it done. The breaker bar was flexed to about 30*. Hey now.
    Senior Member Three Rings MongoMcG's Avatar
    Apr 15 2022
    B8 A4, C2 Corvette, Austin-Healey 3000 BJ8, SN95 Mustang, 36 Ford hot rod truck, A4 B9 S-line, A3 8V
    Michigan
    Quote Originally Posted by Smiker324 View Post
    Oh my. What's a skinny old guy gonna do? I've a new Fluidampr to install. Doesn't sound like the breaker bar from the home improvement store is gonna be up to the task either.
    “The Force is strong with this one.”
    My K04X build thread
    Feb 15 2016
    Cambridge,Ontario
    I'll check what I did, I don't seem to remember any issues when I did mine after my rebuild..
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    May 21 2022
    Boston
    Quote Originally Posted by MongoMcG View Post
    I heard you can rent a fat guy for a 6 pack or a Big Mac!
    Apr 15 2022
    Michigan
    Too funny. Yeah, I have a couple of those.
    Apr 15 2022
    Michigan
    I'm curious, because right now I have a hundred dollar breaker bar in the shopping cart where my wife's Christmas present should be.
    Jul 16 2018
    Atlanta
    It feels like you finished that rebuild a long time ago, no? How time flies. Or just feels like it. The new bolt came into play starting March '21 or so. See if you can still read the strength off the bolt head. It's probably 8.8.
    Jul 16 2018
    Atlanta
    Could be a really expensive $100 breaker bar. :-P Need one of those torque multipliers. But some of these +° specs, seems like they were made for impacts. The bottom rear damper bolt, the lower curved to subframe bolt, the crank bolt. You know the factory isn't using breaker cars.
    Feb 15 2016
    Cambridge,Ontario
    yeah that guy gets lots of work... he put the bolts on that connect my control arms to sub frame on my b7. they were mofos to get off
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    just saw smacs post.. my bolt is the old one
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    oh you are right. didn't realize it was that recent... mine was 2018. makes sense as I'm not that strong , or fat ..... yet ...
    1976 Yamaha XS 360
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    Welp, I've got the 10.9 grade bolt at the old torque spec. Not gonna redo it. I'll let yall know if my engine blows.
    Apr 15 2022
    Michigan
    That torque multiplier thing is an excellent idea.
    Not much happening due to waiting for FCP Euro to resolve an issue, so I did some reading about installing the crank bolt. The 2.0T is a bit easier than some cars for removal and install, but the 100 Nm plus 180° installation torque spec when using a grade 10.9 bolt is still a monster.
    I ran across a few anecdotes about it - no tragedies, just difficulties. In one cat's story he mentions how much the car moved (but not the bolt). So jack stands are a bad idea.
    I watched a video where a guy finished off the +90° (different engine) with an impact gun. I'm pretty certain that's the way the pros do it on the clock. But he overshot it, and that idea does not sit well with me. There are a few other high torque applications in the garage, so Smac's suggestion of a torque multiplier tool (TM) started to make sense to me, and I ordered one. I'll blame him for my wife's disappointed in getting only a new set of coasters for Christmas. It'll be a couple of weeks before the Fluidampr install, but if I remember to do so I will post an update here on how it goes.
    If you are unfamiliar with the TM...
    The TM has been around forever. In modern day form there are some models specifically for lug nuts/bolts for big rigs and such, and others are for hand tools. They use a planetary gear set and a reaction bar (more of a counter-reaction bar, actually) to multiply torque, and they can be had in different ratios and drive sizes. I'm unsure of the math, but apparently there is some loss in the planetary gear system, so on my 4:1 gear model the actual torque multiplication is 3.3. That means 100 Nm of input will yield 330 Nm of output, and each rotation of the bolt will take 3.3 rotations of the input driver. TM's can be used for both installation and removal, and they are a much more elegant solution than a large buddy hanging off the end of a cheater pipe. There can be some loading that can spring back and bite you, so any force on the tool should be released slowly.
    A torque multiplier is on the pricier side for a tool. Even used, a known quality brand will still sell for more than $300 for just the head (no bar). If you are lucky your auto parts store might have one for rental.
    I bought a 1/2" drive input, 3/4" drive output, with a 4 to 1 gear set. It's a tool I'll use maybe a dozen times before I die, so I was comfortable going with an independent brand I found on E-Bay (Mammoth Brand). That cat has a decent story, and the tool comes in a kit with a couple of different reaction bars, plus an articulating 1/2" ratchet and a 3/4" to 1/2" impact reducer, all in an injection molded plastic case for $218. It was the last one in stock of the 4:1 ratio for now, but he also makes 12:1 and 16:1 gear sets. At 16:1 you could just about install the crank bolt with a screwdriver, but it'll take 4 days to drive it in. I also found good deals on quality NOS 3/4" drive impact sockets - a 24mm (Williams brand) to work the crank bolt, and an 18mm (Apex brand) to work the X-brace bolts. The X-brace is another reason I bought this TM tool.
    I will set the 100 Nm initial torque with only the torque wrench, then use the TM with the 24" Gear Wrench 1/2" ratchet for the +180°. What would you guess the 100 Nm +180° yields as a final torque? I'm guessing about 450 Nm, which means I'm guessing I'll still need 136.36 Nm on the input side of the TM. That just sounds way more manageable to this twice attacked heart. The tool's rated torque max is 1000 Nm, and has been tested as high as 2000 Nm (not by me).
    Here's a video (of a Ford 9:1 tool) of how I imagine the tool I ordered will work on the 2.0T. I won't have the fancy dual-duty bracket shown for the Ford tool, so I will use a jack stand to support the tool and the frame rail to brace the reaction bar. I also will not use a flywheel lock (as shown in video), but instead use the standard VW tool to counter hold the crank pulley. You can skip to 1:54 minutes to get to the meat.
    Here is the kit I bought:
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    never reuse a tty fastener.
    B6 S4, B8 A4, 8P A3, and something, something.
    Jul 16 2018
    Atlanta
    I'll be curious how working with the torque multiplier goes. The one thing that got me about it is you need something to brace the counter bar or whatever it's called. Planetary gear set, same as in the ZF transmissions and the Torsen diff. Three levers, if you are levering on one, want one to lever on the fastener, then something has to brace the third from moving. They generally have that long bar that gets hung up on something to brace it.
    Feb 15 2016
    Cambridge,Ontario
    ... or you could strap your engine to some 4 by 4s and have at it if it isn't even in the car ....
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    victory !!!!
    1976 Yamaha XS 360
    Apr 15 2022
    Michigan
    Nice.
