Results 1 to 2 of 2
    Nov 07 2020
    2016 B8.5 Coolant leak
    Need help isolating this coolant leak!
    2016 B8.5 S4 50k miles
    Noticed a static leak overnight for about two days in a row, about 6-10 oz would leak after sitting overnight. Pressure tested and was unable to see exactly where it was coming from, but it was leaking at a steady rate, pooling up right above oil pan and dripping down the front of the block. Deductive reasoning led me to the water pump, but after pulling the pump, I am not 100% sure it was coming from the seal, could it have been coming from the weep hole?
    I planned on replacing pump, thermostat, and the front radiator crossover coolant pipe, at the same time. After pulling the blower, I noticed some pooling of oil under the PCV, so I picked up a PCV valve.
    Any assistance would be great appreciated, pictures of front block with Waterpump, PCV, and thermostat removed.
    Veteran Member Three Rings fstr n u's Avatar
    Jan 20 2015
    I just replaced my water pump on my low mileage 2015 S4...apparently the gaskets on our water pumps are garbage...that would be my bet.
    I replaced mine and could see the coolant stains immediately below where the gasket failed to confirm....no guess work involved.
    2019 Audi SQ5 Navarro Blue Technik w Black Optics Pkg - stock for now
    2015 Audi S4 6MT Glacier White w Black Int (IE Stg 2, Merc Hx, CTS Turbo CAI & CTS S/C Pulley) - my DD
    2006 Subaru STI Hawkeye Murdered Out - larger turbo 400hp - son's car
    1998 Chev Camaro 6MT, LS2 Rear mount Turbo (710+rwhp/710+rwtq @ 14# boost wheels) - summer hooligan
    http://www.youtube.com/@musclecarfan1
    https://www.instagram.com/ryan_baliski/
    https://www.tiktok.com/@winewithryan
