underneath the engine crankcase where the oil collects to be circulated by the oil pump.
Our oil pan Vehicle Fitment
Our oil sump of 2.5TFSI fits with TTRS 8S RS3 8V RSQ3 DAZA/DNWA engine
Specifications of Our product
1L larger than OEM,
EXTRA plate to prevent oil movements under extreme condition
EXTRA BAFFLES INSIDE AND OUTSIDE to cool down the oil quickly and to
keep it at the correct place for oil pickup during extreme conditions.
Color available in black, silver, gold,
Internal baffled design-prevents oil from splattering when vehicle is accelerating
braking or steering.
Our bolt is magnetic which can observe the iron residuals
JDY upgraded Engine Oil Pan is constructed from aircraft-grade billet aluminum
to allow for lightning-fast heat dissipation equaling safer oil temperatures. Here we
use 1L larger than OEM, so that it can inside and outside to cool down the oil
quickly and to keep it at the correct place for oil pickup during extreme condition.
Also, we use here an extra plate to prevent oil movements under extreme condition
designed to help prevent oil from moving around under extreme conditions.
Aluminum Billet helps cooling and stabilizing engine's oil temperature, keeping it
from spiking during harsh driving condition at racetrack. It also adds structural
strength against grounding due to road hazards. This feature is designed to prevent
oil slushing around during hard cornering.
Technical Details
Manufacturer - JDY Performance
Brand JDY Performance
Item Weight 4.5 kg
Package Dimensions 60 45 20
Attention: Please use the appropriate shop manual for your vehicle to obtain specific
instructions. If you do not have an installation manual or enough skills to install this part,
it is recommended that you seek help from a qualified mechanic.
