Results 1 to 7 of 7
    Dec 27 2020
    California
    Replacing the cabin air filter…wtf
    Seems like they could have made an easier design. First being an older guy it isn’t easily accessible considering the difficulty it is to unclip. Just to get a decent view. I tried pressing down with my fingers and damn. Needed up using a screw driver in between the clip and twister to move the panel off of the clip. Now I see why the dealership and or speed shops want near $200.
    That panel door isn’t going anywhere that’s for sure. Next time I will attempted in in the summer when the plastic is more forgiving.
    Rant over..
    Dec 25 2004
    Earth
    Wait till you DIY carbon clean the intake valves!
    While your there might as well change the thermostat and water pump! Then pop in a new set of injectors!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 27 2020
    California
    I applaud your skills. The cabin air filter replacement is difficult enough.
    Jul 06 2020
    wilmington, N.C.
    Quote Originally Posted by Boomerdw View Post
    When i saw the title to your thread, i actually laughed out loud. I knew what it was going to be about. I changed mine a couple of months, and for a cabin air filter it is ridiculously complicated. I am 55 yrs. old, 6'4" about 270 lbs. I am just glad nobody saw me changing it, hahaha
    2016 S3--Apr stage 2,APR downpipe, APR Trans tune, 034 springs and rear sway bar
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    I found it very easy to change... Remove the cover that "hinges" on one side. Pop the tabs on the interior cover. Pull old filter out, remember orientation. Install new filter. Install interior cover by putting lower tabs in and tilt up. Install exterior cover by inserting the tab that "hinges" and press in to click.
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Established Member Two Rings twopointohtee's Avatar
    Sep 03 2007
    Minneapolis
    I think the process is easy, it’s just the fact that you borderline have to be a contortionist to get down there behind the glove box.
    2024 i4 M50 (current)
    2018 SQ5/Mythos Black/Prestige/APR Stg 1/APR IC/AWE Carbon Air gate (current)
    2016 S3/Sepang/Black Optics/APR Stg 2/KW V1/APR IC
    2016 A3/White/Premium
    2008 GLI/White/Autobahn
    2007 A4/Silver/Premium
    2006 GLI/Salsa Red/APR Stg 1
    Dec 27 2020
    California
    Quote Originally Posted by twopointohtee View Post
    This and the tabs I found problematic. Little space between the lower tab that needs pressing and the upper stationary piece above the tab. Just gettin and eyeball on it is also difficult. ghall size alone would make it very difficult.
