Originally Posted by
austin1346
Haha no way, that's EXACTLY what mine looks like. Guess I'll be replacing it.
I found a replacement pump on FCP euro for just over $100 but the gasket is back-ordered. Will have to do some more digging to see where I can get one. Thanks!
I seem to recall that mine came with the gasket.
Give FCP a call, they should be able to verify for you.
While chasing oil leaks, check the oil cooler on the underside of the engine (you will have to drop the front belly pan). The gasket on mine was bad also, causing a significant leak. IF you need to replace this gasket, I would recommend new fasteners (not necessarily oem). As they are aluminum and will BREAK EASILY, causing massive headaches. I broke one of mine inside the block when snugging it up and replaced them with some steel ones and a bit of copper antiseize.
Best of luck!
