Results 1 to 3 of 3
    Established Member Two Rings SteveC's Avatar
    Nov 13 2020
    North Dakota
    Liqi Moly Motor Oil Saver?
    I use Liqui Moly 5W-40 in my 2017 A6 3.0T which I try to change every 5K miles. There doesn't seem to be any obvious leaks, but I seem to have to add oil at least once between changes. A friend suggested Liqui Moly Motor Oil Saver. Supposed to treat seals that may have slightly dried up and shrunk. Not a miracle of course, but for $10 worth a try?
    Anyone use this?
    2017 A6 3.0T Supercharged Premium Plus S Line
    Sport and Cold Weather Packages
    Audi logo puddle lights in my doors, spacers and caliper covers.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    In general these cars burn some oil, probably increasing in likelihood to the harder you drive it. That said, I also have a C7.5 with the CREC 3.0T, just changed my oil last weekend (also use LiquiMoly 5w40) after ~4,000 miles (6 months) and got 6.5 L out whereas my last change in June I put 7 L in. So I was only down 1/2 L in 4k miles, some of which is soaked into the filter. But, 99.9% of my driving is slow commuting on secondary/tertiary roads under 1/4 throttle or so
    A bad PCV valve can cause oil loss, and this is a common issue on this car, could be that or it could be that you just drive it hard enough to burn that much oil
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Nov 13 2020
    North Dakota
    I have an oil change scheduled in a couple weeks. I'll have them check the PCV valve.
