2004 Audi A4 1.8T Avant Quattro automatic
Car would occasionally crank several times before starting. And would occasionally get codes for random misfire and misfire on cylinder 1,2,3,4. But still ran fine. New Coils and plugs didn't solve the problem.
Today we replaced the cam position sensor. Started the car and it ran fine. Decided to also replace the Crankshaft Position Sensor. After replacing the crank sensor, it now runs rough with audible misfires and wants to die while at idle. No Check engine light and not throwing any codes with my cheap OBD II reader. I bought a second Crankshaft Position Sensor locally and we reinstalled it, thinking it was caused by the cheap Crank sensor. Same issue. I can have access to Ross-Tech if needed.
What do I check now? Does the new Crankshaft Position Sensor need to by synced somehow? Could something have been knocked loose while removing the old Crank Sensor wire? We replaced the coil pack wiring harness a few years ago due to brittle wires after it wouldn't start one day.
