Originally Posted by
HudsonBarrett
I replaced the crank pos sensor, and all abs wheel speed sensors. I am still getting an ABS light, Traction control light, and the Speedometer isn’t working.
I also have a CEL: P0501 for implausible signal from Speed Sensor.
Today when I went to drive it, Both lights were not on and the speedometer was working. The car ran Perfectly for the 1st time. The. Then…lights came back on.
I don’t think it could be anything to do with my new sensors and im starting to think it’s my ABS module. I’ve done research about how aftermarket HID can affect the module and the previous owner did have the ballast mounted right next to the module. I can’t find any info on how to test the module. Does anyone have any ideas or dealt with a similar issue?
I had the same issue... speedometer was intermittently not working (showing 0 during driving) which progressively got worse... not showing speed more frequently, plus ABS and 'traction-control' lights... scanned and got the same code 'implausible signal from speed sensor' on left side (maybe right side... but it was definitely one side only).
Originally thought i would swap the speed sensors between left and right to confirm that it was definitely the actual wheel speed sensor, but started googling prior to doing anything and a few threads on other forums came up with those exact, very specific symptoms (speedo stopping working, plus ABS and 'traction-control' lights, plus wheel speed sensor code) and in every case they replaced wheel speed sensors etc without any symptoms being fixed, and then replaced the abs module, which DID fix their issues.
also was stated in some thread by people in the know that what the actual cause of this is an internal connection inside the electronics-portion of the abs module breaks but still sometimes physically connects (hence the intermittent speedo etc). apparently this is repairable but not easy to do, however, the electronics-section of the module can be unscrewed and removed/swapped out for a working electronics-section while keeping the aluminium-block in the car with brake-lines all attached(ie not undoing any brake-lines).
so my options were either to unbolt the plastic electronic-portion (which has a rubber seal and can be re-installed etc) on the abs unit and bolt-in a working, used, electronics-section... or... remove entire abs unit (undo all brake lines etc) and fit used, working entire abs unit.
i did the whole unit (electronics-section and mechanical pump) and all symptoms resolved, without touching/replacing any wheel speed sensors (or any other parts).
once installed, either option needs to be re-coded to the car which is apparently always a pain and takes a few attempts... the workshop that re-coded mine said it took 3 tries and was by far what took the most time. If coding yourself then apparently a code (5 or 6 digits... unsure) must be obtained in vag-com from the original abs-unit before it is removed from the car as this is apparently crucial to being able to re-code the new unit.
