Results 1 to 16 of 16
    Junior Member Two Rings
    Nov 22 2022
    B9 OBD11 and S5 ambient light
    Was wondering if OBD11 can be used to make interior ambient lights brighter than the brightest setting allowed via MMI?
    Thank you
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Not aware of increased brightness being able to be done.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Nov 22 2022
    I asked someone who shared this with me:
    Not a single clue on what this is or what it means
    Senior Member Three Rings Diesel S5's Avatar
    Nov 28 2017
    PA
    If we purchase an OBD 11, will we be able to make alot of these coding changes...?
    If so please give a purchase link...
    Nov 22 2022
    Quote Originally Posted by Diesel S5 View Post
    I am not sure what kind of coding or changes can be made but it’s definitely worth looking in to. My situation can probably be resolved by using brighter aftermarket LED’s to replace OEM but I have to look in to that
    Apr 19 2019
    Toronto, Canada
    You can get them from most of the vendors on here or just get it from Amazon.
    Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
    Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
    Senior Member Three Rings CurvesAhead's Avatar
    Feb 07 2020
    Earth
    Quote Originally Posted by Zeusss View Post
    Go here to code all this:https://docs.google.com/document/d/1...h.a97kg5t8vbb0
    (A/S/RS4, A/S/RS5) Codings
    Last Audited: 2022-09-20
    If you’re viewing this document in “Editing” mode (see top right-ish corner) and you don’t plan on making changes, PLEASE click this >> link on << to view this doc in “view only” mode to prevent accidental changes being made to it. Thanks!
    Table of Contents:
    Preface / Disclaimer:
    Devices:
    OBDeleven: By Voltas IT, LLC
    VCDS / VAG-Com: By Ross-Tech
    Some Coding Information:
    Other Coding Links:
    Security Codes:
    Update Instructions For This Document:
    Template: New Coding General
    Coding Type
    Codings:
    Lock with Ignition On
    Interior Lighting Behavior
    Extend Key Fob Range
    Increase Range of Comfort Window Open/Close with Key
    Disable Automatic Unlock After P(ark)
    Parking Assist Speed Threshold
    Seat Heating Stage 3
    Seat Ventilation Micro Adjust Stage 3
    Showing gear number in D and S
    Turning off side orange/amber marker lights
    Sunroof open instead of tilt
    Scandinavian DRLs
    DRL Rằm p Up/Down When Using Turn Signals
    Disable DRL was ex
    Low Beam with High Beams
    Adaptive Brake Lights (Emergency Brake Light Flash)
    Easy Entry
    Automatic Parking Brake
    Double Beep When Unlocking Doors
    Enable ACC default distance in MMI
    Handbrake up, DRL Off
    Disable Start/Stop (ASS) via AC
    Air Recirculation Memory
    Adjust Cluster Brightness
    Changing Comfort Turn Signal Count
    Turn on Auto High Beams for Premium Plus Cars
    Adjust the volume of the Soundaktor
    Fold mirrors via key fob
    Increase time required to open trunk lid with remote key
    Welcome sound
    Enable MMI green menu
    MMI/MIB2 button combinations
    Euro Parking Lights/Single Side Parking Light
    Audi Active Lane Assist
    Increase Delay for Driver Inactivity for Lanwww.yahoo.com
    e Assist
    B&O Speaker Light Bar (Turn off)
    Allow Navigation Panning while Driving
    Enable use of external SIM
    Automatic Opening of the Car When Approaching
    Disable Seat Belt Chime
    Enable SiriusXM Traffic
    Needle Sweep
    Enable Laptimer shown in DIS
    Enable Sport Display in HUD
    Enable Auto PDC Front
    Enable A/C Eco - Disable A/C Max
    Adjust Massage Seat Time
    Adjust Heated Steering Wheel Temperature
    Change Car Variant Displayed in the Virtual Cockpit
    DRL (Daytime Running Lights) On/Off Option in MMI
    Combine 360 View with OPS View on MMI
    Disable Door Open/Ignition Tone
    Disable Head Lamp / Light Wash
    Wireless CarPlay
    Audit Change Log:
    Most importantly: Have Fun!
    Curves
    2019 Audi S5 Prestige
    Nov 22 2022
    Quote Originally Posted by CurvesAhead View Post
    Table of Contents:
    Devices:
    Other Coding Links:
    Security Codes:
    Coding Type
    Codings:
    Scandinavian DRLs
    Disable DRL was ex
    Easy Entry
    Welcome sound
    e Assist
    Needle Sweep
    Wireless CarPlay
    Audit Change Log:
    Curves
    Thank you so much! According to the doc, I dont think there is anything I can do to make them brighter. Do you know if there is a difference in “pro”?
    Thank you Curves
    Feb 07 2020
    Earth
    Thank you Curves
    You are welcome. I am unaware of anything you can code to make the ambient lights brighter in Pro. However, once OBDEleven is connected and you get inside and look around I would not be surprised if there was a way to do it. The list above is not a complete list, more stuff can be coded when discovered. Note: Make sure to keep good notes when you change something so you can go back and undue it if needed.
    Nov 22 2022
    Would changing and switching things around cause to void warranty? Also is there another larger doc to change for example VC? Add more gauges as I have seen some?
    Thank you
    Feb 07 2020
    Earth
    Thank you
    I have never heard of anyone (in3 years of using OBDEleven) mentioning coding with OBDEleven voided any part of the Audi warranty. Plus, I have never seen/heard of anyone being able to code the VC. Many have asked on AudiWorld: https://www.audiworld.com/forums/aud...cabrio-b9-220/ but the answer has always been: "it cannot be done." If it could be coded it would probably be one of the hottest, coolest mods that you could do, like adding extra gauge faces, but it's not available.
    Nov 22 2022
    Bummer! But i have definitely seen two gauges that show HP and TQ I believe? Might be in an RS dont remember
    Feb 07 2020
    Earth
    Yup, you're right, the RS5 has different options available in the VC. I think they have a G meter too.
    Nov 22 2022
    No wonder i hate the RS line!
    Not really lol
    Nov 28 2017
    PA
    Quote Originally Posted by Burrcold View Post
    There are alot of choices on Amazon, which one would work for us...?
    Apr 19 2019
    Toronto, Canada
    Not sure I follow...it's called OBDeleven. Just choose the one for the phone platform you use (iPhone or Android).
