Hello Audi people! This is my first post, I accidently named the thread wrong, i don't know how to change it.
I really need some help, Couse I'm going mad because of this problem, snow has fallen and i can not drive it :D
I'm from Tbilisi, Georgia and my car is A4 2.0 TFSI Quattro Avant, Stock. once never had a problem before. With 214k km.
Yesterday I changed the timing chain kit by myself, before it had starting problem and i was getting the timing related DTC. also noise.
After assembling, it run well about 5 minutes, after it started misfiring on 2nd and 4th cylinder on idle. Check engine blinks.
Re-checked the timing marks, all seems to be good. Measured distances between cam sprocket marks while crankshaft at TDC. Swapped coils and spark plugs. Measured compressions show 11bar . No other DTC rather than misfire.
Please tell me what to check?
Thank you in advance.
