Originally Posted by
ChicagosPhantom
Yeah, could be interpreted as that....however I was just suggesting that it's not worth it in your case when you already have an upgrade that's a bolt on. In other hand, nice work on figuring out that setup, for sure took some time to and it's a nice fitment. Yet again it's a waste on allroad, you're not benefiting on unsprung weight and rotor is smaller than D3 one.
Everybody is upgrading calipers, but what about that tiny master cylinder and brake booster ?
Didn't take much time at all! Looking at the 17z upgrade info for the front, I could tell that Nissan uses the same rotor center bore, and from there, I went on rockauto and looked at various Nissan rotors to find one that would fit (based on dimensions of other factory rotors, like the D3 A8, B6/7 S4, stock W8, stock Allroad, etc). From there, I went to the junkyard and picked up $7 rotors to test fit; might even use them since they look almost new.
As for master cylinder, I actually think the whole setup will be balanced with the stock master cylinder. Reason being, I'm using Q5 2.0T Brembos up front with the stock rotor size, and looking at the factory Q5 specs, they have a 320mm front rotor (like the Allroad), 300mm rear rotor (a mere 4mm larger than what I will have), and their rear calipers have a 43mm bore size just like the B6/7 S4 rear caliper, with a 25mm master cylinder which is the same bore as the Allroad has. One reason I'm going with the Q5 Brembos is that I want to still be able to run a 16" wheel.
