Results 1 to 9 of 9
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    2016 A6 Premium Plus , tire sensors?
    do they have tire sensors in them? getting new tires and local place has a fee to rebuild them ( to the tune of $125) but if i remember correctly i didn't think they had them in them?
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Dec 24 2019
    TN
    Quote Originally Posted by paul-g View Post
    No sensors.
    Oct 18 2017
    NW Philly
    No sensors. Don't let them charge you.
    Dec 02 2011
    What i thought thanks guys
    Sent from my SM-G981V using Audizine Forum mobile app
    Junior Member Two Rings Dave4501's Avatar
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    I have a 2014 A7 and have been wondering about what's in my tires? The car knows when a tire drops pressure but it doesn't know how much. What is in my rims? I know it doesn't relay the actual pressure but I was thinking that changed by 2016 like the original post is asking.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by Dave4501 View Post
    The C7 and C7.5 A and S cars use the ABS wheel speed sensors to determine whether all wheels are rotating at the same speed (within some margin of error obviously) and when it detects that one or more wheels are rotating at a different speed than the others, it recognizes that as a pressure differential as reduced pressure would result in a tire squatting and having a smaller effective diameter. I assume the system is based on averages over a long-ish distance as simply turning changes relative wheel speed.
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    "The C7 and C7.5 A and S cars use the ABS wheel speed sensors to determine whether all wheels are rotating at the same speed"
    Thanks for that info. So what is inside the valve stem on these cars? Nothing? Where is the ABS sensor located? Within the brake caliper?
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Just a normal rubber valve stem, nothing fancy. The wheel speed sensors are located on each wheel hub assembly, upper knuckle area. The correct term if you want to read more on it; Indirect TPMS (versus Direct)
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    Quote Originally Posted by MattyMarkey View Post
    So if I install new rims on my C7 A7, the tire shop can just use the regular valve stems that were used pre-TPMS? That's good to know.
    I'm about to change my rims and tires on my car.
