Oh, hi. Good morning! Welcome back. Glad you're here. Would you like a cup of coffee? I'm about to go make some now. Let me know if you'd like some.
Oh, and while you're here, mind if I fill you in and ask you a few questions?
I got the crankshaft installed yesterday. Smooth as butter. Well, it's smooth as butter that somebody smeared assembly lube all over, but that seems fine. I checked the piston rings, and they all seem to be ready to go now too. Before I got to installing those, I decided to do the connecting rod bearings first, so that I didn't doink the rings on my workbench and ruin them. That's when I ran into the bearing issue. I ordered the wrong connecting rod bearings. D'oh!
OK, so what did I do? I ordered a set of Mahle bearings from Rock Auto that had the tangs on them. The listing didn't mention the tangs, but looking at it again, the picture sure showed them! My fault, totally. Hopefully Rock Auto has mercy on me, but I don't expect it of them. I'll have to order new ones anyway, so let's do it right this time.
How did I order the wrong set, slash how can you learn from my mistake? Good question. Most of their listings mention whether they've got tangs or not. Sometimes, they will say "not for sintered/cracked rods" if they have tangs. Because my listing said nothing, I assumed it was for a stock application, versus some aftermarket application. Wrong. Or partially wrong--they could have been for stock 20mm wrist pin rods, but I didn't think that was available on my car, so I thought the listing would have been filtered. Is it a USP thing? Anyway, learn from my mistake--verify whether you have tangs, and then make sure you order the right bearings. You can go to the manufacturer's website to double check if you're not sure.
OK, so my question for you, dear readers--oh, and are you sure you don't want coffee? I have plenty here--it's the Starbucks dark roast, which I understand many people think tastes burnt, and I totally get that. If you'd like some, feel free. Chobani creamer is in the refrigerator.
Where were we? Oh yes. What bearings should I put on here? I can go right back to Rock Auto and buy the right set for like $30. No problem. It's just a standard, run-of-the-mill connecting rod bearing, and remember--I'm not going for 400 horsepower here. But I will probably be spending a lot of time at full power and high RPM, so the stress might be almost as high, but for different cause. Should I go over to the ECS Tuning spot and get a set of Calico coated bearings?
If I do go with performance bearings, should I get the ones with the extra oil clearance? I don't understand what extra oil clearance means in terms of bearing performance--does that mean oil pressure will be impacted? Does it mean I need to run a different weight oil? Or is it just better somehow?
Thanks for reading, and thanks for all of the help you've all provided so far! This has been a fun experience, and I hope you all take some enjoyment from it.
