2004 A4 1.8T Quattro: Every winter I end up putting in a new heater core. They get plugged and flushing doesn't restore full heat. I've done a full flush and changed coolant about every other year. Some google searching suggested that a poor ground connection could cause the coolant to be used as a ground, creating electrolysis at the heater core leading to scaling. I measured mine by putting the negative lead on my multimeter on the negative battery post and the positive lead in the coolant reservoir. Measured 0.14V. Is this high? I checked the engine block to frame ground strap and it seems okay.
Thanks
