Starter $40
Alternator $40
IABED vac pump delete plate (custom order these are not easy to find) $100 (use S4 or 3.2 or vw rabbit electric vac pump it bolts into the factory location on A4)
Oil pan with upgraded snub mount $40
Hood (mint stored after re paint) $200 quarts metallic grey
Factory S4 18x8” ET 45 avus wheels, set of 5 + 4 centre caps, santex black wheels have 50,000km and are excellent condition $500 for the set.
Turbosmart IWG75 internal 14 psi wastegate 2 available $130 each.
Engine front cover $20 (with view window)
155 prv $100
Throttle body $20
Vacuum pump $40
Rs4 injectors $160
034 lightweight aluminum flywheel $420
Halogen factory headlights $100 for pair
Injector repair/replacement kits 4 available $20/ injector
07k must haves if your building
Lambo lower intake manifold $160
5 cylinder exhaust manifold flange 1/2” stainless $180
Last chances to those in need. If you’re needing these items get them now b4 they are gone for good.
