Originally Posted by
maxiz1
That's very helpful walky. For now I'm good about confirming the correct WG setpoint. I did ran the boost log and there seem to be a difference of 1.5 psi less at peak boost (8psi requested vs 6.5 psi actual). I could not simultaneous get the N75 duty cycle due to my scan tool limitation but all in all I think it is ok as an ECU tuning is needed to get a major upgrade in performance. I did not ran it up to the redline coz I'm still with the stock auto tranny and it's making a jerk on downshift. Planning to repair that using transgo kit.
I've one question about the DV. I've read people upgrading the DV to stiffer spring when increasing the boost. However from my understanding, I don't think it is required because the factory installation of the DV has the side to be installed on the turbo pressure side. So the pressure will only exert the piston sideways and in no way will lift the piston even if you don't have the equalisation from the top sensing line. Leaks can only happen if the seal is not good but not really a major leak.
If people reverse the installation i.e. bottom connection installed into the pressure side then there is a possibility of lift but still very small due to the equalisation from the sensing line. In summary, I fail to understand why an upgrade is needed unless you want something more reliable i.e. longer lasting and sealing well. Please let me know if I understand this incorrectly.
Because that trend started when people didnt really know why Bosch and Audi made certain things the way they did. It was just plastic vs metal, lets gooo upgrade. Even though metal piston DV'a arent really upgrade, because they always leak, it might be 0.1% it might be 0.01% or 10%. A GOOD 710P will hold all the boost you can throw at it with these small frame turbos.
Same thing with the N249. Its there for a reason, to protect your turbo and give it more life and to operate the car at best possible scenarios when certain variables are met. If you wanna do away with all that you can upgrade an electric DV but it requires ECU tuning and some wiring, but that is the next step.
