Results 1 to 2 of 2
    Established Member Two Rings 2002allroad's Avatar
    Dec 30 2007
    Chicago area
    13 allroad w/stereo sound cuts out with very loud thump from speakers
    I have a 13 allroad with no B&O sound system. Its been upgraded to an android radio but this thump sound happened before I upgraded the radio. sounds like a short coming from the amp/speaker connection and its happening lot more frequently lately. Any idea where I should start first? driver side cargo area where the amps are?
    2013 AR premium plus sports package, silver with matching fenders, 20% tint, Carbon vinyl wrapped interior trim, Dynamic side turn signals
    solowerks coilovers w/KW 30mm spacers rear, Niche M179 Verona 20x9 et25, 255/35/20, (winter) stock 18's with Blizzak w/15mm spacers, 10.25 Android (non Rsnav), wireless CarPlay
    Dec 29 2017
    Phoenix, AZ
    If it were me I'd first make sure the sub is hooked up and the wire isn't route funky. In some cars that sub wire has a tendency to come loose.
    Then yes, I'd start checking the amp wiring in the left rear cargo area.
    I would probably have the radio on and start giggling wires to see if I could reproduce it.
    I honestly haven't messed with the stock amps, but if they're anything like aftermarket amps there's a "turn on lead". Would seem like a simple place to look if that's a thing. Others will probably have to tell you a bit better. While I've added RSNav and swapped around speakers I haven't really messed with much else nor had any issues requiring troubleshooting.
    Sent from my Pixel 7 Pro using Audizine Forum mobile app
    2010 Avant // 2015 Allroad
