Results 1 to 17 of 17
    Dec 02 2022
    67 Mustang fastback, 2013 Q5 3.0T, Ecoboost f150 FX4
    Sonora ca
    2007 A4 Avant 6 speed JHM big turbo, full suspension, *needs engine*
    Recently picked up this beautiful wagon, and after owning it for 3 weeks, I hurt the motor. Not exactly sure what the extent of the damage is, but cylinder 4 is down on compression and the spark plug from that cylinder is damaged. Maybe broken valve or piston? Will need to be towed. Anyway, here's the set-up...
    The b7 Audi avant is the last generation Audi wagon you can get with a manual transmission in USA. This is a 3 owner car that has been meticulously maintained and tastefully upgraded. California car it’s entire life - so no rust or corrosion at all. Paint is in excellent condition. A few very minor blemishes from being a 15 year old car but still in amazing condition inside & out. interior is in near mint condition, no sag in headliner, seats in perfect condition, no rips or cracks.
    118k miles, clean title, deep sea blue exterior, beige interior, s-line wood trim (only 1 of 12 in this color combo confirmed by aoa). Full jhm td05h-r turbo kit installed by jhm (have 16k build receipt from jhm) S4 steering wheel, S4 peelers with conti dws06 tires, S4 brakes, JHM shift kit trio & jhm shift knob. Vogtland coilovers, 034 adj upper control arms, 034 rear sway bar, 034 adj end links, 034 strut mounts, 034 rear diff carrier mount, devils own w/m kit with funk button, p3 digital vent boost gauge, b7 rs4 clutch kit, custom fast intentions exhaust with s4 rear valence, jhm test pipe, jhm fmic, dash cam, Bluetooth adapter, tinted windows, entire build and all performance parts have less than 15k miles.
    Cam follower has been updated with iABED cam follower conversion kit - so you’ll never have to worry about changing a cam follower again. fresh ac service, carbon cleaned, coolant flushed, oil changed, new spark plugs & coils, new cabin filter, new front brakes & rotors, fresh alignment, new fuel pump. Car ran great and was in perfect mechanical condition.
    https://www.youtube.com/watch?v=jrSLEs8Hf5M
    7500$ Car is located in Sonora, CA
    (209) 890-5216
    May 07 2017
    2014 Nagaro Blue S4 Manual
    Cincinnati, OH
    Can JHM fix it? Too much boost? Very nice build and quality components. Need a better idea of extent of repair needed. Interested.
    Dec 02 2022
    Sonora ca
    Quote Originally Posted by Dclove985 View Post
    After talking to couple guys at JHM there seems to be a few different possibilities. It's difficult to narrow down without tearing into the motor and investigating. A lean condition from too small of a fuel pump could be one cause (previous owner swapped in a stock unit after a pump failure). The water/meth injection could've been adjusted wrong as well as the car misfired while the injection unit was activated, and was on when the engine blew. I put a bore scope into the damaged cylinder and could see a piece of the spark plug porcelain sitting on top of the piston. I was unable to see the valves or cylinder wall with the scope, but with the noise the engine made at the time it shut down, I'm assuming it needs a long block, or full rebuild. The spark plug electrode is bent, suggesting something physically hit it. compression on cylinders 1-3 are 150psi, and cylinder 4 is at 95.
    Dec 02 2022
    Sonora ca
    Still have the car, and would love to see it go to a new home
    Dec 02 2022
    Sonora ca
    price lowered to 7500
    Established Member Two Rings rawdyaudi's Avatar
    Jan 29 2017
    Big Turbo B7 Sedan, E39 540i Wagon (For Sale)
    Los Angeles, CA
    I bought this, great seller. Cheers
    Feb 21 2017
    Denver
    you'll have to let us know what the status of the motor is. hope it's just a head replacement or something. paying 7500 for this is really steep IMO
    Nov 02 2018
    WI
    The car and parts are worth more than $7.5k. If you end a sentence with a preposition, keep the names out of your mouth, C…
    Jan 29 2017
    Los Angeles, CA
    Update here, motor has some weird damage. No visual bent rods or damage aside from bent cyl 4 spark plug, but the tone wheel is missing a big chunk. Spoke with a few people and no definite answer but one possibility is that the W/M was over spraying and caused the car to lean out.
    I got a spare motor in the garage for the Avant, should have it all together for only ~2k. This one is gonna be totally factory just drop in rods from IE.
    The turbo kit and goodies are now strapped onto my sedan with a built motor. She’s a ripper! The JHM tune and kit feels really good. Thanks to Dru for helpin out.
    I’m happy with the price and although it is kinda worse case, this is what I planned for.
    If your reading this, thanks OP I’ll shoot you an update over text.
    Jan 29 2017
    Los Angeles, CA
    Not the best photo but you can see the chunk missing from the tone wheel.
    Dec 02 2022
    Sonora ca
    Awesome to hear that your car is on the road putting that turbo to use. I’m pumped that the wagon went to good home. Thank you for the update.
    Jan 29 2017
    Los Angeles, CA
    Quote Originally Posted by Matthew67 View Post
    Hey Matt, yeah man thanks again. I’m back in town this week and gonna pull the motor and start the rebuild. Cyl 4 must have a bent rod that allowed the piston to come down lower and hit the tone wheel - I can’t think of any other possibility.
    Not sure if anyone else has any interest but I’ll post more updates in this thread I guess…
    Jan 29 2017
    Los Angeles, CA
    Just realized this is in the “Audi” thread. Mods pls remove or move to “builds”?
    Jan 29 2017
    Los Angeles, CA
    We’ll I think I got lucky with the damage. Cyl 4 rod is indeed bent, slight damage to the block but I do think it’s reusable. I just dropped it off at machine shop and will get word next week if it’s good. Head is in perfect shape so as long as the block is okay I should have this Avant back on the road by September.
    Jan 29 2017
    Los Angeles, CA
    Moderator please move this thread to “B7 A4 Projects & Builds “
    Jan 29 2017
    Los Angeles, CA
    Last update if anyone cares to hear it.
    Car is running and on the streets again. Threw some IE rods in the motor just incase I want to put the turbo kit back on, bone stock otherwise.
    Im in around $9k for the Avant but got a bunch of parts for my sedan (~$5k). Works for me.
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    Good stuff, I think you did well! Good looking 6MT Avant and a big turbo sedan, what’s not to love!?
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
