    Aug 31 2019
    Corning, NY
    Running a differnt sized tire than the other three on a Quattro
    Hello All,
    So, this is likely a dumb question and will make a lot of you upset someone would even want to do this.
    Yet, I have three new Dunlop Graspic DS-3's and one Dunlop Graspic DS-2 all 235/45R17 and I'd like to run them on my B7 Quattro because I can't seem to find another DS-3 anywhere.
    Anyway, I know there have been a ton of tire size questions on here but they are trying to run different sized tires on the front and back. In my situation I'd have to run a slightly different tire from the other three. How stupid of an idea is this?
    From what I've seen it is recommended to keep it within 3%, but I think this is front to back and not side to side. I've calculated the difference in diameter and they are only 0.39% which to me seems like it should be no issue, yet I don't want to do something really imbecilic.
    Thoughts?
    Junior Member Two Rings
    Sep 01 2021
    Northern Colorado
    If your calculation is the true difference, you're fine. May be larger / smaller depending on wear.
    That percent difference is probably comparable to the effect of driving on a crested country road has on relative wheel speeds.
    Sent from my Pixel 5a using Audizine Forum mobile app
    Jul 25 2019
    Charlottesville, VA
    This is an enlightening article, particularly the fourth paragraph (that begins "As an example...") Full of good info.:
    https://www.tirerack.com/tires/tiret....jsp?techid=18
    What it comes down to is strain/heat/wear to the differential.
    Eric
    2015 A4 2.0T Quattro
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    Same size will be fine. Wanna keep all within 3/32 if possible. But rem, tires do wear at dif rates, and don't cause issues.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The 3% rule is both side to side or front to back.
    Cant say if its good or not, but it would make my brain itch.
    2019 SQ5 Prestige
