Hey everybody,
This seems to be a frequent issue so I'm hoping to get some help with this.
I had a persistent "Active lane assist currently unavailable, no camera view" which come with the "ACC and braking guard unavailable" messages. Wasn't sure if it's the camera failing or bad cable as the VCDS is pretty vague, so I bought a used camera hoping that a replacement would fix the problem. However, when I hooked it up the dash message would flash back and forth, like it's reading the camera but then losing the connection. I let it flash for a little bit hoping this is one of those things that would resolve itself after a few miles. Eventually it stopped flashing leaving only the ACC message in the dash, indicating it may be finally registering the "new" camera. When I press the button for the side assist guide lines in the HUD I would get "Audi side assist unavailable, system fault". At that point I thought maybe I just need to get it calibrated and I would be good to go.
Alas, the next day when I started the car, the dash started flashing again, eventually changing to a persistent error message. Every now and then it would flash and beep again.
Here's the fault codes for the replacement camera:
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7E01010201
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 2809F89BE2774E9B8F3-807C
1 Fault Found:
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 204
Reset counter: 163
Mileage: 185081 km
Date: 2022.09.22
Time: 12:27:06
Control Module temperature: 47 °C
Voltage terminal 15: 14.171 V
Velocity_vehicle_reference: -0.02 m/s
Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001621414
Coding: 00CD077D00
GVL: FDADE84CFEE36C0F4000
ASAM Dataset: EV_GatewPkoUDS 001019
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 72BDDAF3142B744BE17-8026
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 1386834803
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140818000000000001C4
1 Fault Found:
4888 - Camera control module
U107A 00 [008] - No communication
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 203
Mileage: 188148 km
Date: 2022.10.25
Time: 16:25:48
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 37 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: E9060000
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B1AFD5E593F3745-8030
7 Faults Found:
0724 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ACC_timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 121017 km
Date: 2019.01.11
Time: 19:33:18
Outside temperature: 77.0 °C
Voltage terminal 15: 13.7 V
Control Module temperature: 9.0 °C
0232 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Functional_restrictions_low_voltage]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 176
Mileage: 139016 km
Date: 2020.08.11
Time: 03:14:13
Outside temperature: -11.5 °C
Voltage terminal 15: 6.9 V
Control Module temperature: 16.0 °C
0233 - Supply voltage
U1011 00 [008] - Voltage too Low
[Ubat_too_low]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 176
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Outside temperature: 53.0 °C
Voltage terminal 15: 7.4 V
Control Module temperature: 0.0 °C
0552 - Control Module For Camera
C110A 54 [009] - Missing Calibration / Basic Setting
[Calibration_VIN_mismatch]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 162
Mileage: 189771 km
Date: 2022.11.10
Time: 15:42:51
Outside temperature: -40.0 °C
Voltage terminal 15: 11.4 V
0706 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[EGD_Timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 162
Mileage: 189771 km
Date: 2022.11.10
Time: 15:42:53
Voltage terminal 15: 12.6 V
Control Module temperature: 24.0 °C
0600 - Extended CAN Bus (SAE Bus C)
U0046 00 [008] - Malfunction
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 189772 km
Date: 2022.11.11
Time: 07:13:03
Outside temperature: -42.5 °C
Voltage terminal 15: 14.2 V
0716 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Airbag_timeout]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 189772 km
Date: 2022.11.11
Time: 07:13:07
Outside temperature: -42.0 °C
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2615F6A3E86358EBBDF-8072
No fault code found.
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H33 0041
Serial number: 005000122310147
Coding: 03C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
1 Fault Found:
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 163
Mileage: 189617 km
Date: 2022.11.09
Time: 14:37:22
Outside temperature: 13.0 °C
Voltage terminal 15: 13.3 V
Control Module temperature: 29.0 °C
Has anyone had this and were able to determine the source of the issue? I might just have to bite the bullet and pay for a new camera and cable, but any assistance would be appreciated. Thanks.
