Results 1 to 7 of 7
    Nov 30 2022
    Scotland
    2005Audi A4 1.8T BEX Starting Issue and running rough
    Hey all, hopefully someone can point me in the right direction to repair my 2004
    Veteran Member Three Rings Darepoole's Avatar
    Sep 29 2015
    B5 A4 2.0 Stroker, 2016 Touareg, 1984 Pontiac Fiero,
    Saratoga Springs, NY
    Do you have a scanner to scan for faults vcds or equivalent?
    B5 A4 2.0 Stroker (In Progress)
    Nov 30 2022
    Scotland
    Sorry I posted this by mistake before I finished typing, I have just posted the full description above. Cheers
    Nov 30 2022
    Scotland
    2004 Audi A4 1.8T BEX starting issues and running rough
    Hey all, hoping someone can point me in the right direction to repair my 2004 Audi a4 1.8T. Problem I’m having is hot or cold intermittent hard starting (cranks and won’t start first time but always starts on second or third attempt) code was P1128 Lean bank 1. I have changed both Coolant sensors, spark plugs, fuel filter, maf sensor, front 02 sensor and tried a new purge valve. No difference. Strange thing is with the new lambda sensor im getting P0130 code and it keeps coming back straight away after I clear it. The rough running almost feels like a misfire worst around 2500rpm. What else could it be? I somehow managed to make it on a new thread 😂 this is the problem
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    Coils/cam sensor/injectors are the next easiest things to fire the parts cannon at.
    Nov 30 2022
    Scotland
    Had it smoke tested and was a vacuum leak
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Making multiple threads on the same issue is not going to get you different answers. Glad you got it sorted out in the end but patience goes a long way when it comes to asking for help.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
