    Senior Member Two Rings canonball's Avatar
    Apr 20 2011
    Tacoma, WA
    Thermostat on its way out???
    During my commute into the office today I noticed the coolant temp hanging out a just a bit cooler than normal. I'd probably been driving for 30-40 minutes at that point so the engine should have definitely been properly warm. As I got a little closer to work it actually came back up to normal. It was quite cold this morning, when I first noticed it the outside temp was at 32° (F). A few months ago I was sorting out a coolant leak issue and in the process flushed the system and topped it off after, did my best to keep the mixture in the car around 50/50, but if it did get a little watered down would that cause the engine temp to dip when the outside temps get colder? Or is this more inline with a failing thermostat?
    Nov 03 2010
    2019 Audi A5 Sportback, 1986 MB 560SL
    Fallbrook, CA
    Either thermostat of temp sender. How's the HVAC heat? Does it blow warm-hot after a few minutes of driving?
    Apr 20 2011
    Tacoma, WA
    Quote Originally Posted by Turbo510 View Post
    Yeah, hvac seems normal. Everything else seems normal, car runs good. It just seems to fluctuate between the 1/4 mark between cold and normal and normal temp, did the same thing my whole drive home.
    Jul 10 2015
    Colorado
    Is your drive downhill? I have had issues before maintaining heat while driving down long mountain passes here in CO during the winter. Outside temps were below zero and using engine braking.
    Jul 06 2021
    '03 B6 Quattro 1.8T
    Saint John NB
    it's likely a temp sensor. Mine started doing the same thing after I used it to ford a river once, killed the 2 pin sensor at the bottom of the rad.
