Results 1 to 11 of 11
    Junior Member Two Rings B5_A4_SH's Avatar
    Aug 11 2022
    Upstate, SC
    Air Bag Indicator Light
    While driving, air bag Indicator lit up on dash. Any clues?image-2022-11-30-07:31:51-088.jpg
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    99% of times its the connector under the seat, its extremly sensitive. Did you adjust either driver or passanger seat?
    Aug 11 2022
    Upstate, SC
    Quote Originally Posted by Blazius View Post
    I did bounce the seat height up and dropped it using mechanical lever. Trying to get comfy for distance driving lol. Gym time.
    Thanks [mention]Blazius [/mention]
    Aug 11 2022
    Upstate, SC
    Just a quick connect that I need to push together?
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    When you scan the car what is the code? If it’s the seat, the crimps in the female end need to be pushed together by taking the connector apart and removing the crimps from the connector and forcing the two tabs towards the center to make better contact with the male pin connector.
    If the code is 65535, you can buy a reset tool. This code comes on for me when it gets cold outside.
    https://www.audiworld.com/forums/a4-.../#post25767146
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Aug 11 2022
    Upstate, SC
    Quote Originally Posted by Cybersombosis View Post
    Thanks Cyber, I don’t have VCDS and have not been able to stop yet. Would this code register on any OBD reader (e.g. autozone scanner)?
    Nov 13 2009
    Hard to say. If it’s just a generic scanner then no. You have to log into the airbag module to see what the code is.
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    Autozone scanner will not. Especially if you mean the one they use to check your CEL for free.
    Sent from my iPhone using Tapatalk Pro
    Aug 11 2022
    Upstate, SC
    Ok. I’ll start with the connector. After pushing the tabs toward center and reconnecting should I remove the (-) lead at the the battery? Or not needed.
    Mar 15 2018
    Europe
    Quote Originally Posted by B5_A4_SH View Post
    Nah, all I do is push(really wiggle) connector around and you need to delete code and it should be good. At minimum you need a cheap ELM327 based scanner to read and delete it.
    Aug 11 2022
    Upstate, SC
    Danke!
