Results 1 to 6 of 6
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    Shift slow on cold start
    This may be an obvious answer for some, but I am just curious if this is similar to others
    Current perf mods - 3.0t GIAC tune, IE TCU tune, IE Intake, AWE touring exhaust, CTS turbo downpipes
    When cold, do these tunes automatically slow how quickly the transmission changes gears? When i start the car and begin moving a minute later (temp meter has not moved, these cars take a while before they warm up), it takes a while to shift and is quite slow until it is warmed up.
    Example: I start the car, let it run for a minute, then begin driving and using the paddle shifters, going from first to second is really delayed or lagging. When the car is warmed up, its very quick...or on a pull, it shifts within nano-seconds.
    I am assuming (cant emphasize the assuming enough), that these tunes have a calibration to not change gears quickly when everything is cold or not up to temp. Is this true?
    Relatively new to this platform (first winter with a b8.5 3.0t and tune), so i am curious.
    -Brian
    B6 A4 USP OEM+
    B8.5 SQ5
    B8 A4 Avant S-Line Prestige
    Senior Member Two Rings 6SpeedS4's Avatar
    Dec 19 2018
    2016 Audi S4 w/ APR Stage 1 /IE Intake / IE non-res downpipes / AWE Touring / ECS SS Clutch line / M
    Pittsburgh, PA
    Same thing here.
    Sent from my SM-S908U using Tapatalk
    2016 Audi S4 PP / Sport Diff / 6 speed / APR Stage 1 93 Octane / IE Downpipes / IE Intake / AWE Touring / Canyon strut bar / 034 Rear Subframe Mount / ECS Tran Mount / ECS SS Clutch Line / Merc heat exchanger
    2014 Audi SQ5 Prestige / IE Stage 1 91 Octane
    May 20 2010
    Normal for every automatic Audi I've owned.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Normal
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    same, normal
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Jun 13 2010
    South Bend, IN
    Same, and I've had very similar behavior before I changed fluid once, before my TCU tune (034), after the TCU tune revision (also 034), and after a 2nd drain/fill.
    I've found that if you actually give it some throttle angle? Not enough to really do anything but basically not just nearly-idling to the gear change, it acts more "normal." But after 30-60s of driving, max, it's shifting normally in any mode.
    Safety in numbers, it appears :)
    '14 SQ5 P+; 034 Stage 2 ECU tune, 034 TCU tune, 034 CF Intake, 034 RSB, 034 wheel spacers, 034 front and rear spherical end links, Merc Racing H/X, 179mm pulley, Bilstein B8 + 1" H&R Sport drop, Maxton kit sans rear splitter.
