Originally Posted by
DocSean
Good insight sir. While I'm always hunting for easy gains, I worry about introducing a potential leak and going backwards.
No problem at all. My experience may not be the same as others but, that's what we experienced. Either way, I felt like it was a quality part but, unfortunately it turned out not to be in my case.
TToysRuS
Got any vids of your setup? Would love to see
Not really, no. It's a fairly straight forward setup, however. There's a small handful of us in the states with these turbos but, basically it's a nearly full bolt on car with a hybrid that can't even be seen from up top. I will most likely finish this build with getting an Iroz charge pipe and Tial BOV, an intake plenum and runners. My wife's car will be fully setup like that (and it's FBO) on her RS3 with the TC870XT.
jl87
Where was it leaking? I've read anytime the manifold comes off there needs to be a new gasket used. Lots of guys use RTV also when reassembling. There's also a specific pattern for tightening the bolts to ensure proper torque across the manifold.
It was leaking at the flange that attaches to the throttle body. While it was not leaking incredibly bad on my stock setup and only cost me a marginal amount of power, it was exacerbated when I went with the hybrid and tried to push 38+psi through it.
Quattro75#
Hello-
How did you know about the boost leaks? Where were they, so I can check.
Thank you
See above. Also, it was data logged just before the build and the delta between the target boost and actual boost levels would gradually increase as the pull went along. It took a while for the leak to be found but, that ended up being the culprit.
