Ok, I think I'm done editing. Almost.
Here's the image of my damaged pump (right of hoses I'm touching and attached to the car body) and the presumed hoses that attach to it. Thru all this I'm understanding more of what the car had. But still, the previous owner removed several things so I can't know what was where, exactly.
If you look at hose 22 in the coolant layout, it doesn't really show how it's attached at the cooling system. That might not matter, but it doesn't show the non-return valve and associated. My car pic shows the 2 hoses that appear to be the pump hoses. There were broken nipples in both hoses though, so the attachments must've been thrown away or left in the field where the car hit a tree.
My index finger is touching an S shaped hose with stock number
8EO 819 378B which attaches to what looks like a heater pipe going toward the firewall, pipe 24? However, if you smash the hyperlink on the 7zap rendering of hose 22 it displays the same number
8EO 819 378B as is stamped on my S shaped hose. It's clearly not the same hose shape and my hose isn't that hose attached to the pump. It's not likely that it can even attach to the S shaped hose as depicted.
But SWAG to assume it's part of the assembly then I have to obtain that missing link to complete that part of the circuit.
I've yet to determine that they somehow attach to the reservoir downstream in a similar manner as depicted.
