Looks like the front sway is 30mm and the rear is 22mm. As a person who enjoys a little bit of tail-out action, I'm thinking about buying some upgraded sways to shift the balance a little towards oversteer. It seems like there's three options:
1. 034 rear sway only - designed to work with OEM front. Increases rear size to 25.4mm, claims increase of 100-125% over stock rear
https://www.034motorsport.com/034mot...djustable.html
2. Hotchkiss front/rear sport sways - increases front size to 35mm and rear to 29mm, claims an increase of 235-305% over stock rear, and 60% over stock front
https://www.hotchkis.net/product/200...rt-suspension/
3. H&R Performance front/rear sways - increases front size to 32mm and rear to 24mm. H&R doesn't provide any specific stiffness claims, but it's a similar price to Hotchkiss while being a much smaller increase in bar diameter
https://modbargains.com/h-r-sway-bar...-2008-72257-2/
I also know that some parts from 034 are considered of questionable durability, so I wanted to ask those of you who have been running bars for awhile, which do you like or not like? On the surface, it seems like the H&R bars would maintain a similar front to rear balance, which doesn't really seem like what I want.
One other concern, the Philadelphia area has a lot of bad roads, and a lot of poorly constructed driveways. Adding stiffer sway bars would mean that I'm more likely to cock a wheel in the air right? Considering these are AWD cars I wasn't super concerned about this, but I just wanted to make sure I wouldn't put myself at a higher risk of rubbing inside the fenders.
