Looking for some suggestions… have the following issues after manual swap:
- interior dome and spot lights don't work. The buttons light up, but the lights don't work.
- Lights don't flash when locking/unlocking car (coding issues??)
- when opening a single door, all 4 doors show open on the cluster. Exception: if any other door aside drivers door is opened, it shows all 3 doors are open (just not drivers door)
- cruise control works intermittently
- faint high pitched whine while on throttle/load (goes away when decelerating)
- exterior lights don't flash when locking car (coding?)
- Vibration under load but not when cruising on light load - driveshaft??
Otherwise it's a load of fun. Kinda wish I went for an RS4 0A3 instead of an 01E (would prefer shorter gears).
Non swap related issues:
-Power steering line leaking (part with the constrictor)
- sunroof dial switch came loose inside the housing… lol
- rear power shade gets stuck on the deck lid (slightly warped from being in sun?) but works fine if I push the deck lid down
- interior doorcard trim (leather) unglued
- rear power headrests don't work
- drivers lumbar loses pressure after inflating
- intermittent parking sonar functionality (usually goes full beep)
- water leak from firewall (filled with silicone for now) is this common?
- brakes are somewhat mushy after full brake job (bled a thousand times w/ power bleeder and did the vagcom abs bleed)
- where can I get front windshield trim??? Even Audi tradition doesn't have it…
