Hi all, having two faults I can't clear, I have tried running a couple apps and output test, but the same issue persists:
Issue 1:
B12C615 - Bulb for high mount brake light open/short circuit to B+
The high mount third/centre brake light does not come on at all
I have tried to pull a couple fuses and remove the brake light and disconnect it, it never turns on
Issue 2:
B109071 - Defroster Flap motor actuator jammed
B108B71 - Fresh Air recirculation air flow motor actuator jammed
B109113 - Front air distribution door motor open circuit
Basically the two centre vents have no air blowing through them, only the far left and right do. I have tried a bunch of output tests, same issue persists
Any help on these would be greatly appreciated.
