    Mar 11 2020
    Under Blue Skies
    Floor Jack stands question
    I live in an area that sees all four seasons so I change out my wheels and tires twice a year.
    I try to avoid the dealer so I got to my detail shop and use 2 floor jacks at the mounting points did change the wheels and tires. Never had an issue doing this.
    But is it bad for the suspension/frame if the vehicle to use floor jacks twice a year to change wheels and tires or is a lift much preferred?
    Sorry for the newbie question but just trying to see if there are any issues regularly using floor jacks.
    Jul 21 2014
    United States
    As long as you're lifting from the seam welds, I think it's an unlimited number of lifts. I have no reason other than I've never heard of such a thing.
    Mar 09 2018
    2018 RS3
    I'm sure track people change their tire/wheel setup and do brake maintenance more often...
    I tend to use the jack pad locations when lifting. The pinch welds are fine but be cautions and don't fold them over.
    Florett RS3+DS1+034TCU
    Junior Member Two Rings
    Jul 07 2020
    LA
    They're meant to support the car of course, if you're worried you could always use pinch weld blocks. The Quickjack company makes some, I use them often and the bottom of my car looks brand new still.
    https://www.quickjack.com/accessorie...h-weld-blocks/
    2020 Nardo RS3, 200 miles. APR E85 tune.
    Goals: 9's over 140.
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    You jack it properly it should never cause an issue. If you wrench on your cars I'd recommend investing in a quickjack I love that solution as it's easy to store and makes things like rotating tires a snap and super safe.
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
