Results 1 to 3 of 3
    Feb 11 2021
    Upland, CA
    Audi S7 - Strange Noise?
    Whats up Audizine,
    As mentioned I've recently acquired a strange noise coming from my driver front wheel well area. Based on my many previous years of modding, I thought it was the CV Axle, so I replaced both fronts, but the sound is still there. Im sure the CV Axle added to whatever is causing the sound because the axle was indeed shot and the drivetrain feels more solid than before. But the dang sound is still there... Only other thing I can think it may be is my wheel bearing going out, but I've never heard a bad wheel bearing make an intermittent click/squeaking like this before? Usually a bad wheel bearing has a more grinding/growling/vibration noise from my experience... Any help would be greatly appreciated before I go down the rabbit hole buying and replacing parts that could be perfectly fine, youtube video link is below, Cheers!
    Senior Member Two Rings Reecard's Avatar
    Nov 23 2016
    2016_Audi_S7
    Battle Creek, Michigan
    I had something very similar on my SQ5, I did the same as you and replaced the CV axles. Noise was still there. It was time for new brakes so I replaced those and the noise disappeared!! Hasn't been back, I wasn't thinking the brakes as being the suspect but they were. Just a thought.
    Reecard
    2016 S7 | Prestige | Driver Assistance | Black Ops | Cold Weather | Soft Close Doors | Sport Package | Layered Aluminum/Black Wood Inlays | Tornado Gray Metallic
    2016 SQ5 | Premium Plus | Carbon Inlays | Alcantara inserts | Daytona Gray Pearl
    IG: @reecard70
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    i was going to say sounds like brakes and maybe a shield hitting rotor
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
