Results 1 to 22 of 22
Thread: Timing / Manual
    Senior Member Two Rings calebtbay's Avatar
    Sep 06 2016
    2006 Range Rover Sport SC, 1998 Range Rover P38, 2005 Izuzu NQR, 2007 Toyota Forklift
    Bedford, IN
    Timing / Manual
    How’s this timing look? I think it looks good. Should I be able to squish the middle tensioner with my hand? Top chains seem a little loose. What would be good to keep? What must be replaced?
    I found more little bits of what I think is valve cover paint in the oil pickup screen. Kinda feels like plastic.
    I need to get the heads off. Should I leave the adjusters on the ends of the cams and undo the sprocket that drives the cam chain in order to get the chain off?
    All data DIY just got me for $50. They have 3 TSBs and a piston diagram they are calling a shop manual.
    I need the actual shop manual. Is emanualonline (not emanualSonline) going to give me the same laughably incomplete “manual”? Its only 250MB. Im afraid Im about to waste another $30. Im to the point where I MUST have to manual.
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    How many miles? Seems like the bottom one is cracked?
    Maybe you should take the youtube video of JHM instead of a manual.
    https://www.google.nl/url?sa=t&rct=j...TeKvD1cEJ7JqDT
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Sep 06 2016
    Bedford, IN
    Quote Originally Posted by Rol-co View Post
    Good eyes! It does look like the bottom one is cracked. If any are cracked I will probably replace them all.
    It has 150,000 miles and supposedly 90,000 on the timing.
    Sep 06 2016
    Bedford, IN
    It is very cracked. I can’t do anymore this weekend until I get the tool to hold the cams. Ill have to call JH to see what kit I need. $1500-6000. So many options!
    In the JH video they turn the engine from the center of the harmonic balancer at the front. Mine is just a hole. At the flywheel end again just a hole. No way to easily spin the crank. I will need to spin the crank without the heads later. I lined up the cams from the top. Wont have the top when i need to spin to get pistons out. Am I missing something? Are they just jamming a hex in there?
    Sep 06 2016
    Bedford, IN
    Both of the screws on this top passenger side guide are loose. The cover might have been holding it in.
    Senior Member Three Rings All_Black_A4's Avatar
    May 20 2017
    2x B7 S4 Avants.
    Calgary, AB
    You can pick these up for fairly cheap. Some timing tool kits come with it as well. There's also one that bolts to the rear of the crank shaft.
    https://www.amazon.ca/CTA-Tools-1412...20800244&psc=1
    Oh, and if you've gone to all this trouble....and more by the sounds of it then replace all of the guides and tensioners. They might look good know but could fail in 6 months and you'll be back to square one. Not worth the hassle.
    2007 Audi S4 Avant 6MT: JHM Intake manifold and spacers, JHM Long tube headers and FI exhaust, JHM light weight flywheel, JHM light weight crank pulley, JHM Short Shift trio, 034 motorsport engine mounts and Trans mount, Apikol snub mount, Apikol rear diff mount, H&R lowering springs, Hotchkiss rear sway bar, RS4 grille and Maxton carbon fiber side skirts, Full wrap W/Inozetek Midnight purple.
    Dec 12 2020
    Europe (NL)
    Yep, all the guide's for sure but also upgrade to Rs4 ones.
    Check the adjusters also, open them to see if they are wallowed out.
    Clean and check the solenoids.
    Or this
    https://amtuned.com/products/amtuned...-b6-b7-s4-4-2l
    Sep 06 2016
    Bedford, IN
    I think I am going to do the JH Intermediate Kit. This gets me new everything including updated hardened mechanical adjusters. Ill bet my adjusters are worn out. I will only have to reuse the chains and the electronic adjusters. Maybe I can somehow test my electric adjusters once I have them off.
    I ordered the timing tool kit from ECS. JH wants $350, FCP $140, I don’t like ECS but I got it while it was on sale for $75. Ill probably get the wrong tool 3 weeks from now. Or it says backordered for 3 years and never ships.
    I will also need rings, bearings, head bolts, rod bolts, and a mile of gaskets before I get to putting timing back. Oh, and valve seals. Definitely doing valve seals. The backs of the valves actually look really good. Cam lobes look good. No sludge, no metal in the oil. The cats looked great. I guess we will see what the bearings look like. Hopefully the cylinder walls look OK.
    Dec 12 2020
    Europe (NL)
    Am tuned has the adjusters included too, and rs4 guides, and chains, solenoids (not electronic adjusters)
    Sep 06 2016
    Bedford, IN
    So my timing guides aren’t loose. It looks like they are designed to slide a little on the pins. The pins were tight.
    I just put four of the balancer bolts back in and used the pry bar to spin it. I still find it odd I just have a hole while the engine in the video has a drive.
    I think they didn’t replace the tensioners last time they did the timing. Two had broken off holes for the pins. They were way softer than JHMs but they might have had residual oil pressure. Mine make a sad gurgling noise and I can push them in with my hand.
    Last time I took a set of heads to the machine shop I gave bare heads and all the valve train nicely sorted in plano boxes with labels. Well, they didn’t like that. Im just going to take him the assembled heads and the block. Am I going to be able to get the heads off without taking the cams out? It looks like I can but I don’t have a long triple square to get in the head so that stopped me for today. I ordered a set.
    So the JHM timing video was great! But they are only doing the timing. I gotta do heads and bearings and rings. Any more videos?
    When I take the heads off the sequence is outside to inside alternating sides typically in my experience. Is that the same sequence for this? It’s probably more complicated to torque the head back on but Im just removing right now.
    Dec 12 2020
    Europe (NL)
    Removing is removing, doesn't matter wich bolt first.
    Are you going to sleeve the block? , bearings rings and no sleeve?, sleeve and new pistons would be at my list, bearings should be fine if you don't have engine noise.
    Sep 06 2016
    Bedford, IN
    I didn’t know about sleeves. I know its nicosil (probably spelled that wrong) lined and cannot be honed. I was going to swap the rings and hope for the best.
    Never heard of sleeves for this engine. Didn’t know that was a thing.
    Dec 12 2020
    Europe (NL)
    Quote Originally Posted by calebtbay View Post
    Maybe you should look at this.
    https://www.audizine.com/forum/showt...-Picture-Heavy
    Sep 06 2016
    Bedford, IN
    That is truly impressive. That is some incredible dedication.
    When I asked JHM about sleeves they acted like they didn’t know what I was talking about. When I google it all I get is information from 2016-18 about how it was experimental and not going so well.
    I might pay for sleeves if it was easy. Its not easy. If I ruin this block the whole car is getting recycled. Im not doing forced induction. It just isn’t that fast by modern standards. I just want it back to what it was designed to be so after six years of owning it and letting it sit I can finally enjoy it.
    I don’t understand how he got that turbo to fit there.
    Sep 06 2016
    Bedford, IN
    Well by god AM Tuned sleevin’ blocks just like its no big deal. It sure would be nice to take out the only catastrophic factor. About everything can be repaired, except the block.
    Established Member Two Rings Nicksb6s4's Avatar
    Mar 13 2021
    South Carolina
    Keep in mind the top part of the chains near cam tensioners rely on oil pressure to be slack free
    Sep 06 2016
    Bedford, IN
    Quote Originally Posted by Nicksb6s4 View Post
    I want the sleeved block. They want $4000 for that. Redoing both heads $2000. Rebuild the whole engine for me with fresh parts and sleeves. $12000. It really puts into perspective how much this cost. It’s easier to swallow when you don’t see the full cost at the beginning.
    I don’t have $12k for this car. Having them do it all for me is incredibly tempting. I think Ill just have them sleeve the block first. Once my credit card recovers Ill send the heads. Once my credit card recovers Ill get the timing. Im trying to figure out how much more that plan cost over just letting them do it all.
    Jan 10 2020
    2005 Audi B6 S4 Cabrio; 99 Ford Ranger
    Herndon VA
    Looking good! Fun to see you resurrecting this beauty! Russ
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    He sleeved it cuz its a boosted build, going for big power.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Sep 06 2016
    Bedford, IN
    I gave Alex two grand to redo the heads and another $500 for rings and bearings. My god this is expensive. Timing kit will be another two grand, I spent three grand on the JH clutch package. I need valve covers and the starter and alternator refreshed. Im going to be like thirty grand into this stupid car. It better be worth it.
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    There are those of us that believe it is. Welcome to the brotherhood!
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Timing / Manual
    It will be worth it. I just got my Avant back on the road after nearly 16 months and it’s been pure joy ever since. Audi will never give us a V8 paired with a 6MT again.
    Cheers,
    Ry-man
