Results 1 to 12 of 12
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Failing Coolant Expansion Tank Hose
    2022 has been an exciting year for my 9 year old B8.5. Nothing major, just lots of annoying failures. (Coolant tank sensor, coolant tank hose-not the one in the picture below but similar, side mirror ready to fall off, upper timing gasket)
    So I was perusing my engine today and noticed this bad boy:
    If you can see in the picture - the little hose is splitting at the connection point, and there is also some weird crust spot on the hose.
    It's seems to be this part: 8K0121081AH
    https://www.ecstuning.com/b-genuine-...e/8k0121081ah/
    Couple questions - the hose connects to the engine flange, is that difficult to access? Is this an issue that needs to be fixed like in one day, or a couple weeks? I'm gonna be busy with work for the next month, so wondering how high to prioritize this one.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    Put a hose clamp on it, and stop worrying about it.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Established Member Two Rings mrg_B8TFSi's Avatar
    Dec 24 2021
    Audi 2013 A4 Quattro B8, 6-sp man, Audi 1998 A6 Quattro C5, Ford F250 XL 5.4L 4x4
    Northeast PA
    That other side of the hose goes to the rear coolant flange on the back of the head under the vacuum pump and HPFP.. it’s a little bit of a pain to get to.. but if you replace the hose you should replace that flange too, because it’s plastic and prone to break and it’s coming up on years of use. The crust is the G13 coolant it’s designed to cake up to seal a leak when exposed to air it will self seal. The parts are not expensive when it comes to Audi parts . That slight leak isn’t a big deal you probably have a quite a bit of time it’s not critical yet.. just keep an eye on it and your coolant level
    Jun 30 2014
    West
    Great info! You’re on point with Naptown Tuner, found some videos on this topic.
    His videos are awesome, a jedi master on the B8. (but best to skip the non-automotive videos.)
    https://m.youtube.com/watch?v=zU92vqGQypw
    MPG 24city 31hwy
    Oct 24 2018
    Germany
    Quote Originally Posted by audrobotic View Post
    Yeah, the guy is a conspiracy/QAnon nut and pretty much his life is falling apart due to being immersed in that world and it's getting worse. We're not going to see much in the future from him for sure, so be sure to save the videos because he's liable to lose his mind once and for all one day and pull the videos, set them to private, or try to delete the channel after getting raided by the FBI, etc.
    As for the hoses, I recently had an issue with my forward hose where the wire retainer was weak and vibrated to a nearly fully unlocked after driving for hundreds of kilometers on roads with thick ice. The retainer really felt weak.
    Jun 30 2014
    West
    Yikes. Yeah I'll have to save those B8 videos, because they can come in handy in the future.
    Can't you just snap that wire retainer back in? I think I've seen aftermarket replacements for the retainers, other wise I guess you just have to replace the whole hose. I had to replace the forward also a few months ago because of a leak in the hose. Also had to replace the expansion tank because of the integrated sensor going bad, with the dashboard message saying "stop engine, coolant..." something like that - but coolant level was fine.
    MPG 24city 31hwy
    Oct 24 2018
    Germany
    I did and drove back from the Arctic to central Europe without further incident, but it doesn't feel strong anymore, so it's going to be a hose replacement. They're like 14 Euros here.
    And yeah, not a joke about the Naptown guy and the FBI. He's solidly in that direction and becoming more paranoid and militant, so we really should be downloading his videos and hope he doesn't do something stupid, but he's pretty much broadcasting his mental deconstruction and the deconstruction of his life for conspiracies.
    Jun 30 2014
    West
    Yeah that forward hose is pretty cheap, I forgot about that. The rear hose is a bit more expensive, it's about $80.
    MPG 24city 31hwy
    Oct 24 2018
    Germany
    Completely nuts. We have in the high 40 range from Audi and about 27 for OEM. I gotta say I can't believe the prices paid in the US. It was never this much of a spread even into the early 2000s and I would never have one of these cars there. Getting parts here in person is already difficult enough, despite the cars coming from here. Everything has to be ordered and dealers are really not keeping stock on much, including for the B9. The entire industry is signalling shifts, but that's a different story.
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Hmm, ETKA shows the rear hose p/n as 8K0121081CA (PR-GP2), current US VAG dealer list $42 (found for $27 at some VW on-line sources). --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Jun 30 2014
    West
    Quote Originally Posted by DrGER View Post
    Interesting - ECS tuning shows a "AH" suffix part.
    MPG 24city 31hwy
    Aug 31 2014
    NW OH USA
    Yeah, could be, depending on PR codes (GP1 vs GP2) and build date: https://audi.7zap.com/en/rdw/audi+a4.../1/121-121030/ --g
