I had forgotten to say this in the thread. When accelerating somewhat hard I have been getting surging issues, where it will jerk like a failing tranny. A CEL for too rich usually shows up 30 minutes after the event. If I accelerate slow not going over 2500 rpms I usually have no issue. I Have the CVT transmission so It does not usually rev high while changing gears. I had some turbo wastegate solenoid code on my crappy OBD reader but was not sure if that would be causing it. Codes for too rich on idle and also too rich while driving bank 1. Also a pending code for air intake leak. However, I have not been able to diagnose any leaks and boost seemed solid, never going over 6psi during acceleration. This all started when it started getting cold and I was changing my spark plugs and noticed oil in the tubes. I did a valve cover gasket replacement and replaced the HPFP seals and timing cover seals. This fixed my oil leaks, but my plugs became carbon filled after a few days. I was having revving issues when it got cold so that is what brought me to change the plugs. The surging issue did happen before changing the valve cover but not the plugs, just bad idling rpms. Spark plug change is when I had noticed it, but I figured it might have been due to cold or left-over oil in the tubes that had fell in since I torqued them to spec I am not sure how they could be cross threaded. I thought it could have been gapping issues so I switched the plugs about 3 times, but they fouled immediately. I got this car in the summer so I thought it could have been something when the temps get cold outside, but not sure. Hopefully this can solve this, but very odd I never got misfiring codes.
This could be unrelated but my vehicle has also been ticking loud under the hood in the camshaft area, but I figured it was normal from injectors but not sure.
