Results 1 to 3 of 3
    Senior Member Two Rings branden's Avatar
    Dec 18 2006
    Minnesota
    1991 Audi S2 Clone
    1991
    Audi
    Coupe Quattro / S2 Clone
    Silver with Black Leather Interior
    Maintenance Since Jan 2020:
    172,326 - Timing Belt Service
    172,326 - Serpentine Belt
    172,326 - Alternator Belt
    172,326 - Water Pump
    172,326 - Thermostat
    172,326 - Idler Pulley
    172,326 - Fully Synthetic Oil Change
    172,326 - Coolant Flush
    172,350 - Brake Flush
    172,882 - S2 Cluster Install - (Cluster now reads 77,990)
    172,899 Car / 78007 Odo - Wheel Bearings - Remove & Replace - Both Fronts, Inner and Outer Bearings
    172,975 Car / 78,083 Odo - Output Shaft Seals
    172,975 Car / 78,083 Odo - Driveshaft Center Support Bearing
    173,052 / 78160 - Paint Work Legend Autobody
    173,060 / 78168 - Oil and Filter Change Liquid Molly May Full Sythentic
    173,192 / 78192 - Four Wheel Alignment
    173,460 - New Front Winsheild with Solar Sheid Tint
    173,500 - Clutch master cylinder & Slave cylinder
    Upgrades / Mods:
    Fully rebuilt "3B" 5cyl 20v Turbo Motor
    Upgraded Piston Rods
    AMD 3" stainless downpipe
    Full 3” stainless steel exhaust
    Setrab oil cooler with custom lines/mounts
    AMD 3” intake with custom heat shield & 9” K&N filter
    Greddy TypeR blow-off valve
    Ron Davis radiator (replaced in ’18 with new intercooler with custom bell core)
    Spal 14” puller fan
    New Walbro fuel pump
    Spec Stage 2+ clutch kit
    OE S2 intercooler with custom plumbing
    OE S2 6-speed transmission rebuilt with OE RS2 parts
    OE S2 Shift Linkage
    OE S2 hubs (5x112 lugs)
    OE RS2 grill
    OE RS2 headlamps
    OE S2 front/rear bumpers
    OE S2 ABY Speedo Gauges
    OE S2 ABY Aux Gauges
    OE S2 Three Spoke Non Airbag Steering Wheel
    OE S2 Fog Lights and Corner lights (boxed up)
    S2 Fog Lights - New Aftermarket
    S2 Clear Corner Lights - New Aftermarket
    S2 Front and Rear Badges - Jeweler Made
    Porsche 993 turbo brake calipers
    Stainless Steel brake lines
    2bennett coilovers
    H&R springs
    OE B4 hood conversion
    Whiteline rear sway bar
    Powder coated control arms and bits, Delrin bushings
    Leather Cabriolet ebrake handle
    6 speed shift knob
    Tint - Solar Shield - Midwest Clear bra
    Clear Bra - Headlights and Fog Lights
    Vinyl Tinted Tail Lights
    OZ Racing - 18x8 Ultraleggera Wheels - Matte Graphite Silver
    Falken Azenis 225/40/18
    About the car.
    This Audi Coupe spent its extire life in the Seattle Washington area until Jan of 2020 when i purchased it. I have all original paperwork and records since 3000 miles on the car!! Even have the original spare key with dealers tag and numbers on it. Super cool! This car was previously owned by Justin Hoover. Justin and his father had the S2 conversion preformed in 2009 by Addict Motorsport Design. They're an Audi enthusiasts preformance shop located in Woodinville WA. Url to their website: www.fastaudi.com The build was very extensive (list of upgrades above). On top of the S2 conversion, they had the engine fully rebuilt and beefed up with upgraded Piston rods and a thermal coating on many of the engine components. They also upgraded the clutch to a spec 2+, walbro fuel pump, Ron Davis radiator and upgraded core in the S2 intercooler. Also installed, full 3" downpipe and 3" exhaust. The ABY S2 6speed transmission was also rebuilt and they put in upgraded RS2 internals. Car currently has the stock turbo and tune, but with these upgrades it's set up to safely take alot more horsepower if desired.
    Since my ownership the past 2 years, I've done alot of maintenance (see above) and some great upgrades to it. S2 steering wheel, S2 speedometer, S2 aux gauges. S2 aftermarket clear fog lights and corner lights. I had the tail lights tinted with smoked LUXE film. New OZ Ultraleggera Wheels (very light weight) and had the S2 bumpers and lower rocker panels resprayed. (Rockers were a little sun faded and the bumpers had a few blemishes.) I added solar shield UV blocking tint to all the windows, including the brand new windshield I just had installed. The car looks very fresh and clean. Original silver paint is in wonderful condition. No cracks or peeling clear coat. NW car - it hasn't seen harsh sun or any salt. Underside is very clean too. Interior is in great original condition. I had the wood trim vinyl wrapped gloss black and center panels painted satin black.
    I'm very reluctant to sell this S2 as it's one of the nicest examples in the USA. I know I'll never be able to replace it. If interested or have any additional questions please reach out.
    Dec 18 2006
    Minnesota
    Images located here on my craigslist ad:
    https://minneapolis.craigslist.org/h...561655265.html
    I've also got alot more I can text or email. Text or phone call is best for quicker response.
    -Branden
    952.393.7192
    Dec 18 2006
    Minnesota
    Sale Pending!!
