    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Installng LED light bar - 12V?
    Hi
    I've installed a light bar on my A6 3.2 -05. But I don't know where to take 12V from since the battery is in the trunk and there are no battery points in the engine bay on this car. Is there a good place to borrow it from or do I've to route a cable all the way to the trunk?
    Can I tap into the wire for the low beam?
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Aren’t the battery points also in the front on the passenger side?
    Oct 10 2017
    Sweden
    I know there is on most cars but not on this one for some reason. Ground is no problem. Maybe I can take it either from the starter wire or alternator wire?
    Audi TT 1.8T -99
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    There are positive and ground points under the hood on the passenger side, but instead I'd just tap into a fuse on one of the panels in the cabin on driver or passenger side.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Junior Member Two Rings
    Sep 06 2019
    MN
    When I had my '05 there were no pos and neg points under the hood. Weirdly seems like they skipped it that year.
