I have replaced the water pump due to overheating. When I went to rotate the crank to seat the belt the gears under the pump did not turn. I proceeded to get the belt on prying and pushing it on with a screwdriver. Closed everything up and refilled the coolant and started the car but it eventually pegged the temp. gauge. I assume the gears driving the water pump from the engine are not turning. How can I fix these gears or get them to turn. This car is also an oil burner with one cylinder using a spark plug extension to keep it away from the oil and fouling out. I'm a 72 year old working in my driveway trying to save my daughter some big bucks. Thanks for any insights to get this pump cooling the engine.
