Would love to help Jerry, but first thing to know is that you've posted in the B8 S4 section of the forums (covering the S4 model from 2010 thru 2016), rather than the B8 A4 section (covering the A4 model from 2009 through 2016). You really want to start off in the latter, which you can find at this link:
https://www.audizine.com/forum/forum...y.php/97-B8-A4
You should be able to find the support you're seeking on the B8 A4 link. In a cursory look there, I noticed this post, which may give you a head start in solving the issue with your daughter's A4:
https://www.audizine.com/forum/showt...LY-w-o-Housing. The first entry in this post references a link to this thread:
B8 A4 2.0 TFSI: DIY Water Pump Replacement. This Do It Yourself post should suffice to get you on the right track!
Good luck on your project!
