Results 1 to 24 of 24
    Feb 23 2013
    B5/S4,MkI Scirocco, Rabbit Truck, allroad, mkV Jetta, T1 Touareg V8
    KC, MO
    1.8T/2.0T Tiptronic Crankshaft to Manual Pilot Bearing Adapter
    This precision machined bushing converts the Tiptronic crankshaft to the manual crankshaft clutch pilot bearing configuration.
    Allows you to use your tiptronic crankshaft when swapping to a 5 or 6 speed transaxle. New OEM pilot bearing is already installed.
    No machining, grinding, or material removal required. Pull the torque converter pilot bushing and press this in place. No more difficult than replacing a regular pilot bearing.
    Installation instructions will be provided. If you are unsure how to remove the old torque convertor bushing from the crankshaft, please let me know. I can provide you with a simple tool to extract it for only $8 when you purchase the adapter.
    FAQ
    What transmissions will this work with?---01E, 02A, 02X, 01X... if it came in a B5/B6/B7 then this fits
    Do I have to machine my crank for this to fit?---No, the crank does not need have any material removed
    What bearing does this use?---This uses the OE bearing part# 056-105-313c
    Do you sell a bushing to convert a manual style crank to an automatic?---No
    Does this work on my VW engine?----The only VW application is Passat 1.8t’s that we’re mated to Tiptronic
    I've got a FWD with the CVT. Do I need this to convert to a manual? --- No, CVT and manuals use the same crank
    I accept PayPal . Located in Kansas City
    $87.50 shipped in the US. Please inquire about international shipping
    Please contact Chris >>>>> [email protected]
    Feb 23 2013
    KC, MO
    BumP
    Feb 23 2013
    KC, MO
    bUMp
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TtT
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    Ttt
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    ttt
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Another automatic crankshaft converted. Great seller, support this guy instead of trying to use a 2.8 pilot bearing. The 2.8 bearing trick sucks, you can't properly align your clutch with it, its nearly impossible to remove, and I'll never go that route again knowing that these exist. And neither should you! Thanks @Gearbox
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Apr 27 2009
    TX
    Fantastic work! Thank You for engineering and offering this to everyone!
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    tTt
    Feb 23 2013
    KC, MO
    bump
    Senior Member Two Rings Razgriz227's Avatar
    Oct 28 2016
    Arizona
    Sent you an email! TIA
    Feb 23 2013
    KC, MO
    Quote Originally Posted by Razgriz227 View Post
    Sent you an email! TIA[/url]
    E-mail response sent with installation and payment information + expedited shipping cost rates. You will receive a tracking link with your order. Thank you!
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    tTt
    Feb 23 2013
    KC, MO
    Bump
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Got mine yesterday. High quality and great seller!
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
