Results 1 to 3 of 3
    Feb 23 2022
    Montenegro
    Abs module coding
    My abs numbers are 8do 614 111 ab and the other one doesnt have ab on the end,can I code that out and will the car even brake with that module?
    Послато са SM-G960F помоћу Тапатока
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    Why do you wanna remove ABS...? Its quite important.
    Feb 23 2022
    Montenegro
    Quote Originally Posted by Blazius View Post
    I am changing abs module as mine is broken,wheels are blocked on harder braking..so idk if I can change mine with other one that doesnt have ab on the part number as mine does
