Results 1 to 31 of 31
Thread: Trickle Charger
    Nov 22 2018
    Palm Beach Gardens, FL
    Trickle Charger
    I hope everyone had a Happy Thanksgiving!
    I just ordered my 034Motorsports tune and I know that during the time I need to be hooked up to a charger. Any suggestions for a good economical option? Something I can pickup at AutoZone or advanced. Thanks!
    Feb 18 2021
    Colorado
    https://youtu.be/kz-R99ItlU0
    Check this out, they talked about it during one of their live streams. Important to get an actual charger, not just a trickle charger I believe.
    ’20 SQ5 Prestige
    Ibis White, Black Optic
    IG: SQ5_THORN
    Apr 08 2011
    '21 SQ5 & '16 Golf R
    NoVA
    I bought one of these when I tuned my wife’s car.
    Deal of the day: NOCO GENIUS1, 1-Amp Automatic Smart Charger, 6V and 12V Portable Automotive Car Battery Charger, Battery Maintainer, Trickle Charger and Battery Desulfator with Temperature Compensation https://a.co/d/clMfMQU
    iain
    Jul 03 2022
    Northern NY
    I have a CTEK MXS 5.0 smart charger/maintainer. https://smartercharger.com/collectio...s/ctek-mxs-5-0
    I hard wired the pigtails to the charging posts under the hood so all I need to do is connect it and plug it in when needed.
    SQ5 Prestige
    Ultra Blue Metallic, Rotor Gray Nappa Leather, Optic pkg., Sport pkg., Sport Exhaust, Black Rings & Badges, 21" Black Optic Wheels (Neuspeed RSe103's for winter) and other misc. options.
    Established Member Two Rings 383vett's Avatar
    Feb 15 2021
    Moraga/ca
    Quote Originally Posted by ron-sq5 View Post
    I've got a couple of these chargers for my garage. Work great.
    2021 SQ5
    Nov 22 2018
    Quote Originally Posted by hbnoodles View Post
    Thanks! Seems like the want something to maintain high voltage and recommended a 20a charger.
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    I've flashed mine at least 6 times now. I've never been connected to a charger. Definitely don't turn off the engine and blast music with your headlights on for an hour before flashing though.
    Buy a charger though, if you own a car you should own one.
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Nov 22 2018
    Quote Originally Posted by Gunnarrrrr View Post
    I agree.. just trying to make sure I have one powerful enough to charge not just trickle charge but not wanting to spend $100.
    Nov 22 2018
    Schumacher SC1280 15A 6V/12V Fully Automatic Battery Charger and Maintainer for Motorcycle, Power Sport, Marine, and Automotive Batteries https://a.co/d/8ypPQrC
    How about this one? Great price and 15Amp. They say 10% of your amp hours. I believe we have 950AH. Thanks for help!
    Nov 22 2018
    I ordered this brand but the 10A version for $79 reg $130.
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    CTEK is the way
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Veteran Member Three Rings mrmeth90's Avatar
    Jun 29 2007
    Miami
    ABLY Car Battery Charger 8-Amp, 24V and 12V Battery Charger Automotive, Trickle Charger for Car Battery - Smart Fully Battery Maintainer with Temperature Compensation and LCD Display https://a.co/d/16ledeX
    Bought this worked great. Never went below 12.3
    2008 A4 2.0tQ Phantom Black Titanium-APR Stage 2+ --AWE Quad Tip Black Diamond Exhaust--GSG FMIC--GSG CAI--Labree HFC--APR Snub--AWE Boost Gauge--Xenon Retrofit/Blacked out housing/CC Mod--Painted front and rear Reflectors--Lamin-X Tails--ZiZa Pure Yellow Fogs--H&R Coilovers--H&R Rear Sway Bar--
    Next Mods:
    APR HPFP, LED Taillights, BBK (not sure brembo or stoptech) Carbon Fiber Trim, Recaro Seats...
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    you can also wear a condom and life jacket when you flash.
    simple solution. turn on the car acc power and roll down driver window and then turn off ac, radio, and lights, etc. close the door and pull laptop thru window and flash on your hood with a towel under laptop. have good wifi sometimes the dongle gets updates so takes longer than other times. i have atleast 20 flashes this method between EPL and now 034 zero issues
    Sent from my SM-S908U1 using Audizine Forum mobile app
    2018 SQ5 Prestige - AWE Carbon Intake, AWE Touring Resonated Exhaust, RedStar Exhaust HFC Downpipe, Turbo Systems Stage1 Hybrid Turbo, Forge Motorsports FMIC, Forge Motorsports Transmission Insert, Cete Active Suspension Controller, EPL Stage 3 (beta) tune, Carbon Fiber (w/alcantara sides) Steering Wheel, Vorstiener VFF-110 20x9 et35 Zara Gray, APR 10mm Spacers, Ti extended Lugbolts, Suntek Ultra PPF, Cquartz Finest Reserve, Full Cquartz Interior, Formula One Stratos Tint 30%
    Oct 14 2022
    US
    According to 034, it needs to be able to provide 20A in supply mode. This requirement certainly minimizes your options to higher-end professional grade battery chargers.
    NOCO GENIUSPRO25 -$350
    CTEK CS FREE -$300
    These are the cheapest I could find on Amazon.
    The other devices listed in this thread can only provide max 5A. Hell, many users here as well as some 034 videos don’t even connect to a battery charger when flashing.
    ¯\_(ツ)_/¯
    Mar 25 2015
    Placer County
    Trickle Charger
    Just flashed back to the e85 file today with my headlights on and the ac and stereo running just to prove a point.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Sep 07 2018
    Colorado
    Quote Originally Posted by esssssss View Post
    CTEK CS FREE -$300
    ¯\_(ツ)_/¯
    You'll be fine if your battery is healthy to flash without one. But it's a good safety mechanism.
    CTEK is worth the price if you have multiple vehicles or like to store vehicles
    Mar 25 2015
    Placer County
    Quote Originally Posted by DiscoDan View Post
    when your ignition is on, chances are youre pulling more than 5, or even 20 amps. What matters is that your battery is charged. If you have a bad battery, dont do a flash. a trickle charger or even 20 amp charge wont help a bad battery.
    Your battery is able to supply over 600 amps. and an H7/H8 battery is typically 80aH, meaning you can supply that “20 amps” mentioned for 4 hours straight, when fully charged. A flash takes 10 minutes at most to do the ecu and tcu.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Nov 22 2018
    Thanks everyone. I got a decent charger that should help and always nice to have in case the battery decides to go down the road.
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    i just flashed a revised stage3 file today at the drag strip staging lane with my phone hot spot 20221127_111004.jpg
    Nov 22 2018
    Quote Originally Posted by 4-ring-sleepers View Post
    Nice!
    More importantly, what did it run??
    Apr 08 2011
    NoVA
    Any tuner will tell you that switching between maps is significantly faster than flashing from/to a stock file.
    iain
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    my stage3 update took 15 minutes with mobile hotspot
    Dec 28 2020
    I know with previous cars, the trick to doing the long-write initial flash without a battery charger was just to pull the Fuel Pump fuse. Priming the LPFP was responsible for most of the current draw prior to engine start. This along with the usual lights, stereo, AC off, etc. was enough to keep the battery from dying. Has anyone tried this with good results? Looks like the LPFP fuse is A16 in the footwell.
    I’ve got a charger on the way, but may give this a shot for science if nobody else has done it..
    Apr 08 2011
    NoVA
    Quote Originally Posted by asrautox View Post
    The cost of having to replace the ECU if the car dies mid-flash is likely enough to keep most people from trying this.
    iain
    Dec 28 2020
    Probably true. Might be worth a quick experiment if all looks good.
    Dec 28 2020
    Update: Removing the LPFP fuse works.
    For those without a battery charger you can remove the A16 fuse from your footwell fuse box. As always, be sure that your battery has a good charge and hasn’t been sitting for too long.
    You will need a T30 torx bit and various pick tools and/or a small flathead.
    Locate the A fuse box (top left)
    Remove the pink plastic fuse cover by gently pulling outward. Then locate and remove the 30-amp A16 fuse:
    Follow the initial flash instructions (I did both trans and engine one after the other).
    Once the flash is complete, replace the fuse, fuse cover, footwell cover, and cap. Start the car and enjoy..
    Disclaimer: As with any modification there is a risk that something could go wrong. If your battery is too low to begin with, damage may occur. The use of a battery charger will reduce this risk.
    Mar 25 2015
    Placer County
    this is what a giant waste of time looks like
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Dec 28 2020
    Takes all of 5 minutes, but you do you..
    Jan 04 2016
    1967 Ford Mustang Coupe 289 w/ 3 on the floor
    Boston, MA
    I just went with this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It's saved me a few times aside from providing maintenance to the battery for the 1 time I flashed 034 stg 1 ecu + tcu.
    Jumped a friend's car that was dead in my driveway and my neighbors car.
    Affordable peace of mind, I'd say.
    2018 SQ5 - Current | 034 ECU & TCU STG 1 | ECS Tuning Intake | Rev9 FMIC | 034 Inserts | 38% ceramic tint
    2010 S4 Prestige - Sold
    Oct 14 2022
    US
    Quote Originally Posted by Scaughtedaug View Post
    It only provides 2A in supply mode. Far short of the requirement to maintain the battery if it were to die while flashing the ECU. So although a nice piece of mind, it’s quite irrelevant if things were to go south.
    Jan 04 2016
    Boston, MA
    Right, but the flash took like 5 minutes and I just kept it on the 30A.
