Results 1 to 3 of 3
Thread: B&O Issues
    Junior Member One Ring
    Aug 05 2019
    Atlanta
    Question B&O Issues
    All speakers started sounding crazy then bass and subwoofers went out. Amp is good. Can someone help with what codes mean and what I might have to do?
    Thanks
    Address 47: Sound System (J525) Labels:* None
    Part No SW: 8W0 035 465 HW: 8W0 035 465
    Component: MIB2_amp_P_B9 H11 0420
    Revision: 00000001 Serial number: AUZ8ZAHJA03SCFH
    Coding: 0194030800AFAAAFAA0000010000
    Shop #: WSC 06335 790 00001
    ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
    ROD: EV_AMPMst16C2Gen2ALPI.rod
    VCID: 76B5E257C84E781BC1E-8022
    6 Faults Found:
    0592 - Front Left Bass Speaker
    B105F 11 [008] - Short to Ground
    [Verbindungen zu Lautsprechern Kanal 13: Kurzschluss nach Masse]
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 192
    Mileage: 60964 km
    Date: 2022.11.17
    Time: 05:05:41
    Voltage terminal 30: 14.7 V
    0605 - Loudspeaker 2 in Double-Subwoofer
    B130D 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 10
    Reset counter: 176
    Mileage: 60620 km
    Date: 2022.11.10
    Time: 18:51:20
    Voltage terminal 30: 12.0 V
    0590 - Front Left Bass Speaker
    B105F 13 [009] - Open Circuit
    [Tieftonlautsprecher Kanal 13: Unterbrechung (DC-Diagnose)]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 11
    Reset counter: 176
    Mileage: 60389 km
    Date: 2022.11.07
    Time: 20:08:14
    Voltage terminal 30: 12.2 V
    0595 - Front Right Bass Speaker
    B1062 13 [009] - Open Circuit
    [Tieftonlautsprecher Kanal 14: Unterbrechung (DC-Diagnose)]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 11
    Reset counter: 176
    Mileage: 60389 km
    Date: 2022.11.07
    Time: 20:08:14
    0607 - Loudspeaker 2 in Double-Subwoofer
    B130D 11 [008] - Short to Ground
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 192
    Mileage: 58821 km
    Date: 2022.11.03
    Time: 08:45:01
    Voltage terminal 30: 12.5 V
    0600 - Loudspeaker 1 in Double-Subwoofer
    B130C 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 12
    Reset counter: 176
    Mileage: 58420 km
    Date: 2022.11.03
    Time: 05:34:25
    Apr 02 2018
    UK
    Something tells me you have overdriven the system, which is very easy to do. It doesn't take much to blow those woofers. Put better speakers in, or take it to Audi and get them to recode it with the revised parameters which reduces the Bass and they put revised speakers in too. If it were me, I would look to put in better aftermarket speakers.
    Aug 05 2019
    Atlanta
    I think I am about ready to tackle this issue and I could use your assistance. I had already had your upgrades on my list long before this issue, so not the end of the world.
