All speakers started sounding crazy then bass and subwoofers went out. Amp is good. Can someone help with what codes mean and what I might have to do?
Thanks
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA03SCFH
Coding: 0194030800AFAAAFAA0000010000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 76B5E257C84E781BC1E-8022
6 Faults Found:
0592 - Front Left Bass Speaker
B105F 11 [008] - Short to Ground
[Verbindungen zu Lautsprechern Kanal 13: Kurzschluss nach Masse]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 60964 km
Date: 2022.11.17
Time: 05:05:41
Voltage terminal 30: 14.7 V
0605 - Loudspeaker 2 in Double-Subwoofer
B130D 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 176
Mileage: 60620 km
Date: 2022.11.10
Time: 18:51:20
Voltage terminal 30: 12.0 V
0590 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 13: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 176
Mileage: 60389 km
Date: 2022.11.07
Time: 20:08:14
Voltage terminal 30: 12.2 V
0595 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 14: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 176
Mileage: 60389 km
Date: 2022.11.07
Time: 20:08:14
0607 - Loudspeaker 2 in Double-Subwoofer
B130D 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 192
Mileage: 58821 km
Date: 2022.11.03
Time: 08:45:01
Voltage terminal 30: 12.5 V
0600 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 176
Mileage: 58420 km
Date: 2022.11.03
Time: 05:34:25
