So I needed a coolant temp sensor pigtail on my 08 manual s4 because it won’t start just cranks and will try to start here and there. Only code vcds showed when I scanned real quick was fir cts. The one that came with engine was mangled along with the harness side connector. Replaced sensor and tried to finagle mangled connector on but still had code. So decided to try and snip connector off my 05.5 tiptronic and try it on the 08 and hopefully get it started. Now I know it’s a 4 pin connector/sensor, so I cut the connector for out and there’s only two wires actually going to connector. I didn’t look yet to see if the 08 had 4 wires which I figured they both would seeing as it’s a 4 pin sensor/connector and the sensor is actually for the gauge and the signal to ecu. Can anyone verify or disprove whether or not it’s supposed to actually have 4 wires on the 08 and maybe the early b7s (05.5) maybe only had two because u can see there weren’t 4 wires to the 05.5 connector ever because the holes r plugged. The 08 is a half hr drive away and I don’t wanna drive up there to find out it’s not gonna work. Happy thanksgiving and Thank you for reading. PFAIMG_3266.JPG
