Results 1 to 40 of 59
    Nov 23 2022
    Sweden
    Dropping voltage 1volt at Tv22 Audi Q5 2009.
    Is it possible to have a new 35mm2 cable between alternator and Tv22 connection block direct to reducing the voltage drop . The cable between alternator and the starter is the problem of the voltage dropp -1volt. And Audi would like to charge me 2000 euro for the job. Or is it possible to burn relays over time with this idea. Im looking forward on good coments on this.
    Nov 23 2022
    Sweden
    Audi q5 2009
    Tv22 connection block problem.
    Nov 23 2022
    Sweden
    Quote Originally Posted by Tomeri View Post
    Here is the TV22 connection box near the engine.
    Nov 23 2022
    Sweden
    Jul 16 2018
    Atlanta
    Nov 23 2022
    Sweden
    Thank you for the information on this topic. I will order a new alternator cable. I must isolate the old alternator cable at the alternator and mount the new cable from the alternator to TV22. Here is the old alterator cable.IMG_1013.jpg
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Jul 16 2018
    Atlanta
    Oh, so a 2.0 TDI. Wasn't sure what engine you were working with. The V6 have the alternator down under the right side. Definitely a much easier fix with a 4-cyl. Congrats on the DIY.
    Nov 23 2022
    Sweden
    It seems to work super well.
    1. Have you had any more problems with your old alternator cable that is still connected at the other end.
    2. Have there been any other problems with the car's electricity since you did this work?
    Jul 16 2018
    Atlanta
    No, everything is fine, other than the normal issues of aging electronics and wiring. I wrapped the old alternator cable end up in rubber and electrical tape and zip tied it to the side. Been a non issue since.
    I think the electronics in my J367 or my J533 have aged such that they are reading the car voltage too low. My battery would be 12.4/12.5 V but my measuring values are reporting 12.1/12.2 V. I've already confirmed the voltage is fine at the plug into the devices. But I guess after 14 years, a few problems are to be expected.
    But the voltage drop from alternator to battery is now back to acceptable range, a few tenths of a volt.
    Nov 23 2022
    Sweden
    Hello. The car now charges 14v which is good. But something drains the batteries when the car is left standing for a few days. Maybe the car doesn't go into sleep mode because of something. Any ideas on this?.IMG_2868.jpg
    Skickat från min iPhone med Audizine Forum
    Jul 16 2018
    Atlanta
    Not sure what all those screen caps are suppose to convey. You have VCDS, run the autoscan, save (not print) the log to a file, post the file content here so it can be seen.
    You could have some device keeping the car awake, not uncommon. A failed amp unit can keep rewaking bringing back up the infotainment bus members, etc. Another had a problem with the electromechanical steering rack that kept waking the car systems back up.
    The normal approach is to start by manually latching the doors and trunk and waiting a few hours and then measuring the voltage drop across all the fuses on both ends of the dash and the right rear of the trunk and converting those to current flow (scalar varies with fuse type and size; voltage drop fuse charts are on the internet) and trying to what fuses are still supplying substantial current flow when everything should be asleep.
    Nov 23 2022
    Sweden
    Wednesday,31,May,2023,15:03:21:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 20.4.2.0
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WAUZZZ8R2AA052341 License Plate: AAA
    Mileage: 217420km-135098mi Repair Order: 123
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 42 46 52 53 55 56 62 69 72
    VIN: WAUZZZ8R2AA052341 Mileage: 217420km-135098miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAHA) Labels:| 03L-906-022-CAG.clb
    Part No SW: 03L 906 019 AS HW: 03L 906 022 B
    Component: R4 2.0l TDI H03 9977
    Revision: 11H03---
    Coding: 01210023240F2920
    Shop #: WSC 41842 004 1048576
    ASAM Dataset: EV_ECM20TDI03L906019AS A01011
    ROD: EV_ECM20TDI03L906019AR.rod
    VCID: 7CFDA932F7EB6E664F-8028
    1 Fault Found:
    7144 - Please Check DTC Memory in CAN Gateway (J533)
    U1008 00 [047] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 216194 km
    Date: 2023.03.26
    Time: 14:45:24
    Engine speed: 881.00 /min
    Normed load value: 23.1 %
    Vehicle speed: 0 km/h
    Coolant temperature: 69 °C
    Intake air temperature: 22 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.820 V
    Unlearning counter according OBD: 40
    Crankshaft speed (RPM): 881.0 /min
    Vehicle speed: 0.00 km/h
    Accelerator position: 0.00 %
    Vehicle voltage terminal 30: 13820 mV
    Coolant temperature: 69.2 °C
    Generator power: 308822 W
    Engine torque: 40.6 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 8R2 927 156 C HW: 0B5 927 156 K
    Component: 0B5 20 TDIRdW H03 0002
    Revision: --H03--- Serial number: 0000001168
    Coding: 000001
    Shop #: WSC 04940 001 00001
    ASAM Dataset: EV_TCMDL501021 A03002
    ROD: EV_TCMDL501021_A03.rod
    VCID: 3D7B6436AC71A76E38-8068
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
    Part No SW: 8R0 907 379 M HW: 8R0 907 379 M
    Component: ESP8 quattro H06 0020
    Revision: -------- Serial number: --------------
    Coding: 0DD548
    Shop #: WSC 58839 001 1048576
    VCID: 4A913FEAE5BF00D68D-801E
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 DP HW: 8K0 907 064 DP
    Component: BCM2 1.1 H02 0326
    Revision: 00002001
    Coding: 010500
    Shop #: WSC 06335 000 00000
    VCID: 0103D8C69809038E1C-8054
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0509000062145012
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 0209000081848014
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
    Component: KLIMA 1 ZONE H06 0140
    Revision: A1000000 Serial number: 0103.09.080283
    Coding: 36000000
    Shop #: WSC 42043 004 104857
    VCID: 70E58D02A3A31A06E3-8024
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H28 0380
    Revision: 10028001 Serial number: 00000000499223
    Coding: 2600D0914074AF010001000300001D0D0F1C67080001010100 0000
    VCID: 3C7D6932BF6BAE660F-8068
    Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS416 091026 H10 0041
    Serial number: 90243014091024021714
    Coding: 01DD13
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 10655612
    Coding: 024D25
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Serial number: 00000000002210092215
    Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
    Part No SW: 8R0 959 655 C HW: 8R0 959 655 C
    Component: AirbagVW-AU10 H39 0560
    Serial number: 003FQD05RCBQ
    Coding: 30423331313030303030554A304C38523053
    ASAM Dataset: EV_AirbaAU10SMEAU416 002004
    ROD: EV_AirbaAU10SMEAU416.rod
    VCID: 448D11D2CF9BD6A677-8010
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME4C237669M
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME4C241942C
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME1D404426B
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME0542291CD
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME07403E38
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME4F400220R
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8K0 953 568 E HW: 8K0 953 568 E
    Component: Lenks.Modul H16 0014
    Revision: -------- Serial number: 90315IJL0006Q
    Coding: 000007
    Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
    Part No SW: 8R0 920 930 D HW: 8R0 920 930 D
    Component: KOMBIINSTR. H10 0255
    Revision: 00000000 Serial number: CJL4072C9
    Coding: 0F06220002000008010000
    VCID: 356B7C169C417F2EF0-8060
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 S HW: 8T0 907 468 J
    Component: GW-BEM 6CAN H06 0105
    Revision: HB600050 Serial number: 5000H09A0680CC
    Coding: 00C303
    VCID: 51A3288608E9330ECC-8004
    3 Faults Found:
    02071 - Local Databus
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 216194 km
    Time Indication: 0
    Date: 2023.03.26
    Time: 14:58:58
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.80 V
    Count: 6
    Bin. Bits: 10000
    02252 - Generator
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 216194 km
    Time Indication: 0
    Date: 2023.03.26
    Time: 15:25:09
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.70 V
    Count: 6
    Bin. Bits: 10000
    00458 - Control Module for Battery Monitoring (J367)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 27
    Mileage: 216194 km
    Time Indication: 0
    Date: 2023.03.26
    Time: 15:25:09
    Freeze Frame:
    Bin. Bits: 11111
    Voltage: 13.70 V
    Count: 6
    Bin. Bits: 10000
    Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
    Part No SW: 8K0 857 511 D HW: 8K0 857 511
    Component: FLA H04 0004
    Revision: AA001002
    Coding: 02012064747464545425363E
    VCID: 3261470A6D2F6816D5-8066
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
    Component: TSG FA H11 0306
    Revision: Serial number: 0000009551368
    Coding: 011D02204000440004
    VCID: 458B0CD6CCA1EFAE60-8010
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0123406077
    Coding: 013A0620203900000420053280000000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
    Component: TSG BF H11 0306
    Revision: Serial number: 0000009587909
    VCID: 448D11D2C79BD6A677-8010
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000358056
    Shop #: WSC 00000 000 00000
    VCID: 346D4112973B6626C7-8060
    Address 55: Headlight Range Labels: 8K0-907-357.clb
    Part No: 8K0 907 357 B
    Component: Dynamische LWR H01 0030
    Revision: 00000001 Serial number:
    Coding: 0000006
    Shop #: WSC 06334 000 00000
    VCID: 346D4112573B6626C7-8060
    Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
    Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
    Component: Concert3 H05 0310
    Revision: 00000008 Serial number: AUZ5Z6I1296661
    Coding: 05000480040501000159070000
    Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
    Component: Display
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000102198438
    Coding: 010C02204000240004
    VCID: 428117CADD8FD89645-8016
    Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
    Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
    Component: Anhaenger H09 0100
    Revision: 1A001001 Serial number: 00000185497323
    Coding: 0100000000000000
    VCID: 36697B1A81477436F9-8062
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000102198420
    End-------------------------(Elapsed Time: 03:35)------------------------—
    Nov 23 2022
    Sweden
    Any ideas where to start on this drain battery issues ? BR //Tomeri
    Jul 16 2018
    Atlanta
    You have a LIN bus failure for the LIN bus that connects the voltage regulator, battery monitor, and energy management control module. So before supposing a parasitic drain (and I already discussed how one normally starts with that, testing the fuses after the car sleeps to see what's still pulling power), you need to fix that. A broken charging system management system is not going to help your cause.
    Is the plug plugged into the alternator, and the plug on the battery negative plugged in? If you unplug both and measure resistance from the pin 1 violet/blue to pin 1 violet/blue, what do you get? The connection at the J533 is pin 2 on the 20-pin plug. So you'd ideally get a low resistance measurement between any of the three pins, as it's a bus wire with all three connected to it.
    Nov 23 2022
    Sweden
    Test on the lin bus going on seems to be fine with 0 ohm. And voltage in sleep mode with the trunk open and lights off 12,2volt.
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    The car system voltage is 14volt . Im having alot of charging problems over the years with 4 pcs of new car batteries within 5 years and alot of problems with programing new BEM codes into the cars computer. In vcds it says the memory is full could it be a softwere problem ?. And the old alternator cable is still not connected to the alternator only to the starter. Please se pictures at the beginning of the topic.
    Nov 23 2022
    Sweden
    It says redir fails when testning hvac?
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Anouther thing is the memory in can gateway j533. How could i check that and could i clear that memory if it is full?.
    Jul 16 2018
    Atlanta
    You already posted a full scan showing you have errors from the CAN Gateway. "check DTC memory" = "see if you have codes". And the CAN Gateway has codes, it says it cannot manage the alternator or battery voltage because the LIN bus that connects them is failed. That's the only thing you need to be working on in regards to the charging system on that vehicle right now. As long as the J533 cannot interact with the VR or the J367, you will have charging system problems.
    I wouldn't take "0Ω" as a good reading, unless maybe it's rounding down. I'd expect something more like 1Ω or 2Ω. But something is clearly wrong with the LIN bus line. You need to figure out what. The wire from all three devices is going to be spliced together. You need to test all three pins against each other and figure out who isn't talking to who.
    J533 pin 3 > T17e pin 15 side a
    J367 pin 1 > T17e pin 15 side b
    VR pin 1 > T17r pin 11 > T17e pin 15 side b
    So things seem to come together at plug T17e, which is the red 17-pin plug at the base of the driver's side a-pillar, the big connector station with multiple 17-pins and some fuses.
    T17r is the white 17-pin in the ECM box. This is where the wire from the VR plug passes into the ECM box and then the T17r plug, where the other half connects to the interior harness that carries on to the T17e plug.
    That all said, the timestamp on those DTCs are months ago, with only a fault frequency of 1. Clear all DTCs and see if they come back. That VCDS version is old, too.
    I already mentioned what needs to be done on the battery drain issue. You have to isolate where the current is flowing when the car should otherwise be sleeping. The quickest route to that, assuming the issue is downstream from a fuse, is to measure the voltage drop across all the fuses and see which converts to a high current flow. youtu.be/lRcj1fQcWwU
    redir fail is just a VCDS label file issue. B8.5 A4 had this forever until they finally fixed it. Notice how all the other modules have a .clb label file. All you can do here is log your scan to the ross-tech support and see if they fix the missing or mismatched file.
    Nov 23 2022
    Sweden
    Okey will do that tests. Thank you for your time. I’ll put the results here
    Nov 23 2022
    Sweden
    Yesterday, my car almost stalled (stopped )when I was going to work. And the volts stepped from 13v to 14v as it should. Before this happened it has been 14v constant in 6 mounth from when I start the car until I turn it off. so the battery management system is working right now. But I will measure voltage in sleeping mode with a clamp meter with DC current measurement. It is easy to lock the doors and look through the windows at the clamp meter in the trunk Whats going on. It should be interesting how much current that will drain the car battery in sleeping mode.
    Nov 23 2022
    Sweden
    I did some more Vcds tests before I bought a Clamp DC meter. I need help/input to evaluating all Vcds data.
    19 can gateway 007 test have an error code 59. I dont know what that means ?.
    Battery sensor comunication status group 006 = BDM 0. Shouldnt that be BDM 1?.
    61 battery regulator = no response from controller?.
    So something isnt right i belive. Any ideas on this?.
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Jul 16 2018
    Atlanta
    Why are you trying to access 61? There's no such thing on a B8. Stick to the control modules under Installed and Installed 2, ie the ones the CAN Gateway says actually exist on your vehicle.
    I have no idea what measuring block 007 for the J533 is reporting. My error code is 221. I have no reason to presume it's related to measuring block 006. Measuring block 006 is Generator 1 and BDM 1 for me. Do you have values in measuring blocks 014 and 018? Does 015 report any faults? Note, 014 and 015 are about the generator, so the values are not meaningful unless the engine is running.
    I don't know of any resources for interpreting the error codes in measuring block 007.
    Nov 23 2022
    Sweden
    In 018 there is no data at all. It's strange because it should be an error code at least ?.
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    There is data on group 014 but no data on 015 not even error code ?. It should be ?.
    Jul 16 2018
    Atlanta
    Yeah, it should say Not OK (engine off) or OK (engine on). You seem to have values in 014; voltage always has something but that you have the field signal and field current and response time, the communication seems to be there.
    But like 015, your 018 is empty. I notice in both cases, they are the third group. Is the situation the same if you put 015 and 018 in the first group? The values for 006 were with it also in the third group.
    That VCDS version is old. Bring it up to date?
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    Nov 23 2022
    Sweden
    There is a fault in J367 today (Battery sensor) Maybe thats why there are no data in 014 015 018 ? What Do you think ?.
