Results 1 to 13 of 13
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    Best Place For O2 Sensor Replacement (OEM, Bosch)
    Car Background:
    2004 Audi A4 1.8T with nearly 230K Miles. Mods listed below in signature.
    Hello Everyone,
    I recently scanned my B6 to see if I had any intermittent codes and the following code kept coming back the last few scans / months:
    CEL Code:
    17522 - Oxygen (Lambda) Sensor; B1 S2
    P1114 - 008 - Internal Resistance too High - Intermittent
    Looking at Ross-Tech Wiki I found the following:
    http://wiki.ross-tech.com/wiki/index.php/17522/P1114
    I'm going to assume my O2 sensor is starting to crap out after being on the car for 15+ years and over 200K Miles. Trying to be smart and want to go ahead and replace BOTH O2 sensors, and only looking at OEM or Bosch brands since I want to make sure I'm buying quality parts.
    Question:
    Does anyone have a good source of where to get a replacement that won't break the bank?
    Thanks everyone for your help, it is super appreciated!
    Thanks,
    Asif
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, VMR 708s (RS4 Reps), Boost Brothers FMIC, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    Veteran Member Four Rings Cybersombosis's Avatar
    Nov 13 2009
    Victoria, B.C., Canada
    Amazon. I pick them up for around $100 Canadian.
    https://www.amazon.com/Bosch-17351-O...2-8997e41410bb
    2001.5 Audi A4 1.8TQMS - Brilliant Black on Black Onyx Sport Cloth
    Motoza Hybrid K04 Tune, FT F4-H, Bosch EV14 550cc, AEM Water/Meth Injection, Majesty FMIC, SSAC Cat Back Exhaust, Podi Boost Gauge, ATP Test Pipe, K&N air filter, HID fogs, eBay short shifter, Aero wiper kit, Eibach Pro-Kit springs, 18” B6 Ultrasport, Firestone Indy 500.
    2001 Audi S4 SRM K24 RS6 build
    Feb 12 2004
    Austin, Texas
    Quote Originally Posted by Cybersombosis View Post
    Thanks! Did you buy these exact ones you sent the link for? Some of the reviews say they don’t work for B6 1.8T models.
    Nov 13 2009
    I did. No CEL since January.
    Feb 27 2011
    Winnipeg
    I usually buy whoever makes the OE sensor, in this case the OE sensors are Bosch so thats what I stick with
    Feb 12 2008
    Michigan
    the TT sensor is the same and much cheaper, the wire harness is a little shorter than the a4, I had no trouble fitting it though. there is a post in here about it, everyone was buying from advanced auto and using online coupon;)
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Rockauto
    Feb 12 2004
    Austin, Texas
    Thanks everyone! Quick question, can I use the same O2 sensor for the 2 that are required on the 1.8T?
    Or are they different O2 sensors?
    Thanks everyone and happy holidays for those in the US!
    Oct 09 2008
    Fcp euro
    The Awesome™
    Jun 12 2014
    Tampa FL
    Quote Originally Posted by A4orce84 View Post
    When you go to order the parts, you will be guided by the search engine to make sure you get the correct parts.
    On Rockauto, there are two Bosch parts, one economy and another premium/oem.
    Get the better ones.
    You can use rockauto or ecs tuning as a part number search and then get it somewhere else,
    But they generally cost the same anywhere..
    Feb 12 2004
    Austin, Texas
    Thanks everyone! So, one more question:
    Question:
    Are both the 'lower' and 'upper' O2 sensors the same (same PN)?
    Thanks,
    Asif
    Nov 13 2009
    No they are different. Different connector and number of wires.
